Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim DTA S60 Interface Lead MXL Evo - AimShop.com
    ECU-DTA
    I lager, redo att skickas
    £80.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £80.00
    Aim DTA S60 Interface Lead MXL EVO
    Aim Looms, Cables, Connectors and Harnesses are highly engineered to withstand the intense rigours of the Motorsport environment.
    Aim developed special applications for many of the most popular ECUs. By special applications, we mean user-friendly systems which allow you to easily connect your ECU to our high tech data logger. You only need to install a harness between the logger and the ECU.
    Once connected, the logger displays (and/or records depending on the logger on the ECU data stream and configuration) values like RPM, engine load, throttle position (TPS), air and water temperatures, battery voltage, speed, gear, lambda value (air/fuel ratio) analogue channels
    • Öppnas i ett nytt fönster.
