Aim EPM Power Distribution Interface
SKU: EPM
- Vanligt pris
£1,000.00£1,200.00INC VAT - UK only
- Vanligt pris
- Försäljningspris
- £1,000.00
The EPM offers an easier solution to a traditional fuse box by distributing power to multiple circuits in your vehicle directly from the Aim Dash.
With 8 high side outputs, the Aim EPM becomes central to your vehicle’s electronics system. This gives you greater control and simplifies the wiring harness and electronic installations.
Housed in an anodised billet aluminium case, the EPM is designed to handle the rigours of motorsport and includes a complete professional data logger and internal dash controller.
AIM EPM WORKS WITH ALL AIM DASH/DISPLAYS
Easy Replacement of Traditional Fuse and Relay Systems.
LEDs:
- 8 integrated freely configurable RGB LEDs
- 1 PDM status
- 1 PDM <<on>>
Inputs:
- Pull-up +12V, +5V, analogue/digital
- Pull-down
Power outputs:
- 8 rated up to 20 A, 1 with series diode
- Protected for: over voltage, under voltage, over current, over temperature
- Total max current: 120 A
CAN connections: 1 Aim CAN Bus
Connectors: 1 AMP connector + 1 Amphenol SurLok connector
Body: Anodised Aluminium
Dimensions: 122.0 x 94.6 x 46.1mm
Weight: 400g
Waterproof: IP65
- Aim EPM
Technical Specifications
LEDs:
- 1 PDM status
- 1 PDM <<on>>
Inputs:
- Pull-down
Power outputs:
Weight: 400g
Waterproof: IP65
What's In The Box
- Aim EPM
