{"product_id":"aim-kart-steering-angle-rotary-potentiometer-belt-type-sensor","title":"Aim Kart Steering Angle Rotary Potentiometer\/Belt Type Sensor","description":"\u003ch3\u003eAiM Steering Angle (Rotary Potentiometer\/Belt Type) 1 Rev Kart Sensor\u003c\/h3\u003e\n\u003cp\u003eThe AiM steering angle sensor and bracket are suitable for use with all AIM MyChron kart dash\/data loggers (this includes MyChron 5 S, MyChron 5 and MyChron 4, both single and two temp versions).\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eMeasures \u0026amp; records driver steering inputs\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eCompatible with MyChron 4 \u0026amp; MyChron 5 s\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e4 pin 719 male binder connector\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eOptional patch lead\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eAiM Steering Angle (Rotary Potentiometer\/Belt Type) 1 Rev Kart Sensor\u003c\/h3\u003e\n\u003cp\u003eThe AiM steering angle sensor and bracket are suitable for use with all AIM MyChron kart dash\/data loggers (this includes MyChron 5 S, MyChron 5 and MyChron 4, both single and two temp versions).\u003c\/p\u003e\n\u003cp\u003eThe sensor supplied with or without the patch lead required to connect the sensor to the MyChron expansion box, the standard method of connecting additional sensors to your system.\u003c\/p\u003e\n\u003cp\u003eMeasures and records the driver steering input using a sensor (rotating potentiometer) to measure the displacement between two points\u003cbr\u003eYou can see where then the driver is losing time due to steering angle, too much or too little at every corner.\u003cbr\u003eCompatible with the MyChron4, MyChron5 and MyChron5 S\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConnections\u003c\/h3\u003e\n\u003cp\u003eAn optional patch lead is available to purchase with this sensor. The extension cable is for connection to the MyChron Expansion Box.\u003c\/p\u003e\n\u003cp\u003eThe patch lead needed for this sensor is the 712-719 male to female 4 pins and is available in different lengths from 50cm to 400cm. In the Accessories Tab.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_Kart_expand_your_system.png?v=1624538604\" data-mce-fragment=\"1\" data-mce-src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_Kart_expand_your_system.png?v=1624538604\"\u003e\u003cbr\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAiM Steering Angle (Rotary Potentiometer\/Belt Type) 1 Rev Kart Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eThe Kart steering potentiometer electrical characteristics:\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eNominal resistance: 10kΩ\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTolerance on the resistance value: ±5%\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003ePrecision (%): 0.034\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eThe Kart steering potentiometer mechanical characteristics are:\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eMechanical displacement: 270° +\/-10°\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTemperature working range: -55\/+125°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eDissipated power at 40°C: 1.6W\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eDissipated power at 70°C: 1W\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e4 pins Binder 719 male connector\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Steering_Angle_Rotary_Potentiometer_Belt_Type_1_Rev_Kart_Sensor.png?v=1625748685\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM Steering Angle (Rotary Potentiometer\/Belt Type) 1 Rev Kart Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 1G Kart Steering Rotary Potentiometer\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 Toothed Belt\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 Allen Key\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2 Toothed Pulley\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 Bracket\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cdiv style=\"text-align: left;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/product-documentation\/car-sensors\/pdf\/Posistion\/RotaryData.pdf\" title=\"User Guide\"\u003e\u003cimg style=\"float: none; display: block; margin-left: auto; margin-right: auto;\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1613601281\"\u003e\u003c\/a\u003e\u003c\/div\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Steering_Angle_Rotary_Potentiometer_Belt_Type_1_Rev_Kart_Sensor_User_Guide.pdf?v=1625750586\" title=\"AiM Steering Angle (Rotary Potentiometer\/Belt Type) Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/support.aimshop.com\/product-documentation\/car-sensors\/pdf\/Posistion\/RotaryData.pdf\" title=\"User Guide\"\u003eUser Guide\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Steering_Angle_Rotary_Potentiometer_Belt_Type_1_Rev_Kart_Sensor_User_Guide.pdf?v=1625750586\" title=\"AiM Steering Angle (Rotary Potentiometer\/Belt Type) Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":32151258267750,"sku":"S-SA-K","price":115.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_steeringAngleRotaryPotBeltType_00_1.5x.webp?v=1763567488","url":"https:\/\/www.aimshop.com\/sv\/products\/aim-kart-steering-angle-rotary-potentiometer-belt-type-sensor","provider":"AimShop.com","version":"1.0","type":"link"}
