Gå till produktinformation
1 av 4
OTK Magnet Holder For Throttle Position Sensor
SKU: B-OTK-T-MH
Vanligt pris
£25.00
Vanligt pris
Försäljningspris
£25.00
This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.
Suits AiM throttle position sensor kit Specific OTK karts
Fits to the throttle cable
This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the magnet to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the sensor is available to purchase separately.
  • Suits AiM Throttle Position Sensor Kit
  • Suitable for OTK Karts
  • Fits to throttle cable
  • 1 x Magnet Holder for Throttle Position Sensor
