Gå till produktinformation
1 av 3
OTK Sensor Holder For Throttle Position Sensor
SKU: B-OTK-T-SB
Vanligt pris
£25.00
Vanligt pris
Försäljningspris
£25.00
This holder is specific for the sensor used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.
Suits AiM throttle position sensor kit Suitable for OTK karts
Fits to the throttle cable
This holder is specific for the sensor used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the sensor to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the magnet is available to purchase separately.
  • Suitable for OTK Karts
  • Compatible with MyChron4 and MyChron5
  • 1 x OTK Sensor Holder For Throttle Position Sensor
