Aim SmartyCam GP HD Camera U Bolt Mount
SKU: SM-UB-GP
- Vanligt pris
£80.00£96.00INC VAT - UK only
- Vanligt pris
- Försäljningspris
- £80.00
Aim SmartyCam GP HD Bullet Camera U Bolt Mount
The SmartyCam GP HD 2.1, 2.2 & 3 (bullet camera) U bolt mount has been designed to hold and position the bullet camera.
Suitable for 0.5 to 1.2" bar | For SmartyCam GP HD 2.1, 2.2 & 3 |
Aim SmartyCam GP HD Bullet Cam U Bolt Mount
The Aim SmartyCam GP HD U bolt mount is for mounting a SmartyCam GP HD 2.1, 2.2 & 3 to your vehicle. The mount has been designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2".
The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
U Bolt Mount
Securely attaches to any rollbar, railing or tube with a diameter of 0.5 to 1.2"
- For use with SmartyCam GP HD 2.1, 2.2 & 3
- 60mm (2.36 inches) arm
- U bolt
- 60mm arm
- Ball head
- Bullet cam bracket
The SmartyCam GP HD 2.1, 2.2 & 3 (bullet camera) U bolt mount has been designed to hold and position the bullet camera.Key Features :
The Aim SmartyCam GP HD U bolt mount is for mounting a SmartyCam GP HD 2.1, 2.2 & 3 to your vehicle. The mount has been designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2". The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.U Bolt Mount
Includes a rubber insert and lock nuts for a secure fit.A solid ball and socket system for optimum positioning.
- U bolt
- 60mm arm
- Ball head
