AiM Solo 2 DL GPS + ECU Motorcycle Track Day Lap Timer
SKU: SOLO2-K4
- Vanligt pris
- £630.00
- Vanligt pris
- Försäljningspris
- £630.00
+ moms (endast Storbritannien)
Direct ECU data logging
Predictive lap timing
Automatic track recognition
Internal 4 GB memory
Wi-Fi connection
10 configurable RGB LEDs
Choice of connection
The AiM Solo 2 DL GPS + ECU Motorcycle Track Day Lap Timer is a revolutionary device that is changing the way riders track their performance on the race track. This cutting-edge tool combines a GPS receiver with an ECU interface, providing riders with accurate and detailed data about their lap times, speed, and performance. Whether you're a seasoned pro or just starting out, the AiM Solo 2 DL is a must-have for anyone looking to improve their skills and push their limits on the track.
One of the key features of the AiM Solo 2 DL is its GPS receiver, which allows for extremely accurate lap timing and track mapping. The device is able to track your position on the track with incredible precision, giving you real-time feedback on your lap times and speed. This data can then be analyzed and compared to previous sessions, allowing you to pinpoint areas where you can improve and increase your overall performance on the track.
In addition to its GPS capabilities, the AiM Solo 2 DL also features an ECU interface that allows the device to communicate directly with your motorcycle's engine control unit. This means that the AiM Solo 2 DL can provide you with detailed information about your engine performance, including RPM, throttle position, and gear selection. By analyzing this data alongside your lap times and speed, you can gain valuable insights into how your engine performance is affecting your overall track performance.
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
- Solo 2 DL
- Power cable with AC adapter
- User manual
Wi-Fi connection
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
