Gå till produktinformation
1 av 1
AiM Solo External Power Lead 3 Pin Unterminated Motorcycle
SKU: SOLO-EX
Vanligt pris
£42.00
Vanligt pris
Försäljningspris
£42.00
The AiM external power lead fits the AiM Solo GPS Lap Timer.
3 pin - 712 male binder connection Unterminated end with 2 wires
 Suitable for Solo 2 & Solo 2 DL
External Power Cable
The AiM external power cable fits the AiM Solo GPS Lap Timer. It features a 3-pin 712 male binder connection, which goes into the Solo GPS Lap Timer.
The un-terminated wires allow you to connect to an external battery.
This allows Solo GPS Lap Timer to have longer running times.
Please Note: This cable is for the older model Solo GPS Lap Timer.
  • 3 pin - 712 male binder connection
  • Unterminated end with 2 wires: 12V+ & Ground
  • 2m length cable
  • Solo External Power Lead
The AiM external power cable fits the AiM Solo GPS Lap Timer. It features a 3-pin 712 male binder connection, which goes into the Solo GPS Lap Timer. The un-terminated wires allow you to connect to an external battery. This allows Solo GPS Lap Timer to have longer running times. Please Note: This cable is for the older model Solo GPS Lap Timer.
  • 2m length cable
