{"product_id":"aim-suspension-potentiometer","title":"Aim Suspension Potentiometer","description":"\u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n    \u003c\/style\u003e\n\u003cp style=\"display: none;\"\u003eSteering Angle Sensors are high-precision rotary potentiometers that measure the angular position of a car's steering wheel. It's used by motorsport professionals to fine-tune steering inputs for improved track performance\u003c\/p\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eWhat Is A Steering Angle Sensor?\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eThe Aim Steering Angle Sensor is a high-precision rotary potentiometer designed to measure the angular position of a car's steering wheel. It's widely used by professional racing teams and enthusiasts to analyse and fine-tune steering inputs for improved performance on the track.\u003c\/p\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" alt=\"Car Steering Angle Sensor\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Steering_Angle_Sensor.png?v=1626249936\"\u003e\u003c\/p\u003e\n\u003chr\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eHow Does A Steering Angle Sensor Work?\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eThe potentiometer is required to measure the displacement between two points using a sensor (linear potentiometer) directly connected to the points of measurement. This potentiometer can be used to measure linear displacements like:\u003c\/p\u003e\n\u003cul class=\"TextBoxes\" style=\"list-style-position: inside;\"\u003e\n\u003cli\u003eSuspension and spring cushion compression or extension.\u003c\/li\u003e\n\u003cli\u003eSteering column rotation measured through the rack displacement.\u003c\/li\u003e\n\u003cli\u003eWing or spoiler deflection at speed.\u003c\/li\u003e\n\u003cli\u003eShock and suspension travel.\u003c\/li\u003e\n\u003cli\u003eRide height.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003chr\u003e\n\u003ch2 class=\"LandingPage-CatTitle\"\u003eConnections \u0026amp; Compatibility\u003c\/h2\u003e\n\u003cp class=\"TextBoxes\"\u003eWe offer a range of sizes for the potentiometer, for both the pop end and rose joint fittings: 50mm, 75mm, 100mm and 150mm. As a simple guide, most cars use 100mm on both the front and rear suspension.\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003eThis sensor integrates seamlessly with Aim Data Loggers and Dash Displays, providing real time feedback on steering behaviour. The potentiometer comes with a 30cm cable as standard, but to extend the length or connect the steering angle sensor to an Aim device, please select the 719-719 patch lead option. \u003cstrong\u003eNote\u003c\/strong\u003e: If connecting to an \u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-evo4s-car-racing-datalogger\" title=\"EVO4S Data Logger\"\u003eEVO4S Data Logger\u003c\/a\u003e or \u003ca href=\"https:\/\/www.aimshop.com\/collections\/car-hubs-expansions\" title=\"Aim Channel Expansion\"\u003eChannel Expansion\u003c\/a\u003e, use a 712-719 patch lead.\u003c\/p\u003e\n\u003cp class=\"TextBoxes\"\u003eIf you’re unsure which connectors you might need for your setup, please don’t hesitate to contact our \u003ca href=\"https:\/\/www.aimshop.com\/pages\/support-home\" title=\"Aim Support\"\u003esupport team\u003c\/a\u003e.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/downloads\/software-downloads\/\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eSteering Angle Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\u003cstrong\u003eAvailable in the following sizes:\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e50mm - Pop End Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e75mm - Pop End Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e100mm - Pop End Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e150mm - Pop End Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e50mm - Rose Joint Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e75mm - Rose Joint Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e100mm - Rose Joint Fitting\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e150mm - Rose Joint Fitting\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eWhat's In The Box\u003c\/h5\u003e\n\u003ch3\u003eSteering Angle Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 x Steering Angle Sensor\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/9.4Data_Rose_Fitting.pdf?v=1662992414\" title=\"Technical Sheet\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" data-mce-fragment=\"1\"\u003e\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/9.4Data_Pop_End.pdf?v=1662993969\" title=\"Technical Sheet\"\u003e\u003cimg style=\"display: block; margin-left: auto; margin-right: auto;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" data-mce-fragment=\"1\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"Aim Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"Aim Race Studio 3 Software Download\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cmeta charset=\"UTF-8\"\u003e \u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/9.4Data_Rose_Fitting.pdf?v=1662992414\" title=\"Technical Sheet\"\u003eRose Joint Technical Sheet\u003c\/a\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"Technical Sheet\" href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/9.4Data_Pop_End.pdf?v=1662993969\"\u003ePop End Technical Sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":43035445133414,"sku":"SUS-POT-150-RJ","price":235.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_suspension_SteeringPotentiometer_00_1.5x.webp?v=1761835650","url":"https:\/\/www.aimshop.com\/sv\/products\/aim-suspension-potentiometer","provider":"AimShop.com","version":"1.0","type":"link"}
