{"product_id":"aim-tyre-temperature-sensor-bracket-kit","title":"Aim Tyre Temperature Sensor Bracket Kit","description":"\u003ch3\u003eAiM Tyre Temperature Sensor Bracket Kit\u003c\/h3\u003e\n\u003cp\u003eThe AiM Tyre Temperature Sensor Bracket is a dedicated kit to ensure the secure mounting and installation of the sensors.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eFor use with the Tyre Temperature Sensor Kit\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eBrackets for four sensors\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Sensor_Kit_Main_Image_2.png?v=1625564238\"\u003e\u003c\/p\u003e\n\u003ch3\u003eAiM Tyre Temperature Sensor Bracket Kit\u003c\/h3\u003e\n\u003cp\u003eThe AiM Tyre Temperature Sensor Brackets are a dedicated kit for the secure mounting and installation of the four sensors which will use it.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe kit includes four brackets and fittings, enabling the optimum mounting of the sensors in the correct place to get accurate temperature readings from all four tyres.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConnection\u003c\/h3\u003e\n\u003cp\u003eWhen installing the Tyre Temperature Sensor brackets, ensure that the sensors are installed away from strong heat sources, like the exhaust gas pipe and keep away from electromagnetic interferences.\u003c\/p\u003e\n\u003cp\u003ePlease refer to the technical sheet in the Downloads Tab for all information, including images, diagrams on how to fit the sensors to the brackets and your Kart.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eOptional Extras\u003c\/h3\u003e\n\u003cp\u003eSpare Tyre Temperature Sensors are available should you wish to carry spares. 712-719 4 pin patch leads are also available to purchase if reserves are required.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eAvailable in the Accessories Tab.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Sensor_Kit_Main_Image.png?v=1625562450\"\u003e\u003c\/p\u003e\n\u003ch3\u003eTyre Temperature Sensor Kit\u003c\/h3\u003e\n\u003cp\u003eAbove shows the Tyre Temperature Sensor Kit, which requires the bracket to fit the sensors. Available in the Accessories Tab.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_MyChron_14mm_Under_Spark_Plug_Temperature_Sensor_Kart_Expand_your_system.png?v=1625490542\"\u003e\u003c\/p\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eAbove is an example of devices that you can add to your system to enhance your racing performance.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAiM Tyre Temperature Sensor Bracket Kit\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eFront Right, Front Left, Rear Right, Rear Left Brackets\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eScrews M6 \u0026amp; M5\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWashers\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003ePlease refer to the user guide on how to install the the tyre temperature brackets\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Sensor_Bracket_Kit_Technical_Drawing.png?v=1625577525\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM Tyre Temperature Sensor Bracket Kit\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eFront Left, Front Right, Rear Left, Rear Right Brackets\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eM6 x 25mm screws\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eM3 x 10mm screws\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eM5 x 20mm screws\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eM6 nuts\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eM5 nuts\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWashers\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Sensor_Kit_User_Guide.pdf?v=1625560945\" title=\"AiM Tyre Temperature Sensor Kit User Guide\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/User_Guide_AiM_iCON_2289456f-97fa-4d13-84ea-3ede554821e9_100x100.png?v=1590766826\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Brackets_Kit_for_Kart.pdf?v=1625573254\" title=\"AiM Tyre Temperature Bracket Kit Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Sensor_Kit_User_Guide.pdf?v=1625560945\" title=\"AiM Tyre Temperature Sensor Kit User Guide\" target=\"_blank\"\u003eUser Guide\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Tyre_Temperature_Brackets_Kit_for_Kart.pdf?v=1625573254\" title=\"AiM Tyre Temperature Sensor Bracket Kit Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":31333769052262,"sku":"S-TT-BK","price":155.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_TyreTemperatureSensorBracketKit_00_1.5x.webp?v=1762774288","url":"https:\/\/www.aimshop.com\/sv\/products\/aim-tyre-temperature-sensor-bracket-kit","provider":"AimShop.com","version":"1.0","type":"link"}
