{"product_id":"aim-oil-pressure-sensor-0-300-psi","title":"\u003ctc\u003eAim\u003c\/tc\u003e Oljetryckssensor 1\/8 NPT 0–300 PSI","description":"\u003ch3\u003eAim Brake Pressure Sensor 0-300 PSI\u003c\/h3\u003e\n\u003cp\u003eThe Aim 0-100 bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\" style=\"width: 100%; height: 19.5938px;\"\u003e\n\u003ctbody\u003e\n\u003ctr style=\"height: 19.5938px;\"\u003e\n\u003ctd class=\"AimCell\" style=\"width: 30.6055%; height: 19.5938px;\"\u003e 0-300 PSI\u003c\/td\u003e\n\u003ctd class=\"AimCell\" style=\"width: 66.5373%; height: 19.5938px;\"\u003e4 pins 719 male binder\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eAim Brake Pressure Sensor 0-300 PSI\u003c\/h3\u003e\n\u003cp\u003eThe Aim 0-300 PSI brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all Aim loggers and dash display\/loggers.\u003c\/p\u003e\n\u003cp\u003eWhether your car is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make real changes and identify issues quickly and precisely.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe sensors can be easily installed in a -3 brake line using a three-way T-piece. It can also use them for measuring other pressures too high for the 0-10 Bar sensor. Available with an 1\/8th NPT thread.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConnections\u003c\/h3\u003e\n\u003cp\u003eMXS \/ MXP \/ MXG \/ MXL (Strada and Pista) \/ MXL2 \/ EVO5 \/ MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display\/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eEVO4 \/ EVO4S logger \/ Channel Expansion are fitted with 712 connections and require a 712 - 719 patch lead to connect these sensors.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAim Brake Pressure Sensor 0-300 PSI\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cb\u003eSupply: \u003c\/b\u003e8-16V\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAccuracy:\u003c\/strong\u003e \u0026lt; +\/- 0.5% FS (CLNH – combined non-linearity and hysteresis)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eOutput signal:\u003c\/strong\u003e From 0.5V to 4.5V\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCharacterisation:\u003c\/strong\u003e 500 mV\/ 0 bar 4500 mV\/ 100 bar\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eConsumption:\u003c\/strong\u003e \u0026lt; 10 mA\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eTemperature working range:\u003c\/strong\u003e from -20°C to 135°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eSealing:\u003c\/strong\u003e IP66\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eHousing:\u003c\/strong\u003e 316 stainless steel\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight:\u003c\/strong\u003e 30g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCable Length:\u003c\/strong\u003e 400mm\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Brake_Pressure_Sensor_Dash_3_3_8_24_0-100_Bar_TECHNICAL.png?v=1624457905\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Brake Pressure Sensor 0-300 PSI\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAim Brake Pressure Sensor 0-300 PSI\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Brake Pressure Sensor 3\/8 24 0 - 100 Bar Technical Sheet\" href=\"https:\/\/www.aimtechnologies.com\/support\/sensors\/Datasheet_Pressure0-100Bar_3824_102_eng.pdf\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Brake Pressure Sensor 3\/8 24 0-100 Bar Technical Sheet\" href=\"https:\/\/www.aimtechnologies.com\/support\/sensors\/Datasheet_Pressure0-100Bar_3824_102_eng.pdf\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":44246724804710,"sku":"S-P-NPT-300","price":190.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/300PSI.png?v=1765881533","url":"https:\/\/www.aimshop.com\/sv\/products\/mal-olje-tryck-sensor-0-300-psi","provider":"AimShop.com","version":"1.0","type":"link"}
