{"product_id":"aim-oil-pressure-sensor-0-150-psi","title":"\u003ctc\u003eAim\u003c\/tc\u003e Oljetryckssensor 1\/8 NPT 0–150 PSI","description":"\u003ch3\u003eAim Brake Pressure Sensor 0-150 PSI\u003c\/h3\u003e\n\u003cp\u003eThe Aim 0-150 PSI pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 150 PSI. This sensor will monitor brake pressure levels for optimum performance accurately.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable style=\"width: 100%; height: 19.5938px;\" class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr style=\"height: 19.5938px;\"\u003e\n\u003ctd style=\"width: 30.6055%; height: 19.5938px;\" class=\"AimCell\"\u003e 0-150 PSI\u003c\/td\u003e\n\u003ctd style=\"width: 66.5373%; height: 19.5938px;\" class=\"AimCell\"\u003e4 pins 719 male binder\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eAim Brake Pressure Sensor 0-150 PSI\u003c\/h3\u003e\n\u003cp\u003eThe Aim 0-150 PSI brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all Aim loggers and dash display\/loggers.\u003c\/p\u003e\n\u003cp\u003eWhether your car is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make real changes and identify issues quickly and precisely.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe sensors can be easily installed in a -3 brake line using a three-way T-piece. It can also use them for measuring other pressures too high for the 0-10 Bar sensor. Available with an 1\/8th NPT\u003cspan\u003e \u003c\/span\u003ethread.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eConnections\u003c\/h3\u003e\n\u003cp\u003eMXS \/ MXP \/ MXG \/ MXL (Strada and Pista) \/ MXL2 \/ EVO5 \/ MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display\/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eEVO4 \/ EVO4S logger \/ Channel Expansion are fitted with 712 connections and require a 712 - 719 patch lead to connect these sensors.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAim Brake Pressure Sensor 0-150 PSI\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cb\u003eSupply: \u003c\/b\u003e8-16V\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eAccuracy:\u003c\/strong\u003e \u0026lt; +\/- 0.5% FS (CLNH – combined non-linearity and hysteresis)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eOutput signal:\u003c\/strong\u003e From 0.5V to 4.5V\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCharacterisation:\u003c\/strong\u003e 500 mV\/ 0 bar 4500 mV\/ 100 bar\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eConsumption:\u003c\/strong\u003e \u0026lt; 10 mA\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eTemperature working range:\u003c\/strong\u003e from -20°C to 135°C\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eSealing:\u003c\/strong\u003e IP66\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eHousing:\u003c\/strong\u003e 316 stainless steel\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eWeight:\u003c\/strong\u003e 30g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\n\u003cstrong\u003eCable Length:\u003c\/strong\u003e 400mm\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Brake_Pressure_Sensor_Dash_3_3_8_24_0-100_Bar_TECHNICAL.png?v=1624457905\"\u003e\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Brake Pressure Sensor 0-150 PSI\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAim Brake Pressure Sensor 0-150 PSI\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/sensors\/Datasheet_Pressure0-160Bar_3824_102_eng.pdf\" title=\"AiM Brake Pressure Sensor 3\/8 24 0 - 100 Bar Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/sensors\/Datasheet_Pressure0-160Bar_3824_102_eng.pdf\" title=\"AiM Brake Pressure Sensor 3\/8 24 0-100 Bar Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":44246715367526,"sku":"S-P-B-","price":190.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/150psi_70179bd3-2873-4547-a77c-3a7b3a753897.png?v=1765879924","url":"https:\/\/www.aimshop.com\/sv\/products\/mal-oljetryck-sensor-0-150-psi","provider":"AimShop.com","version":"1.0","type":"link"}
