{"product_id":"out-of-production-aim-sw4-270-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 280 Formel Ratt","description":"\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_bCFQLY\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDataloggningsratt\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula Steering Wheel 4 270\/280 är bland våra mest avancerade motorsportrattar hittills. Den har en intern datalogger med komplett konfiguration, avtagbara handtag, vridbrytare och en lång lista med helt kompatibla ECU- och CAN-anslutningsalternativ.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_3kEhi6\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eVarför välja \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 Ratt\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula-ratten 270\/280 har utformats specifikt för professionella motorsporttillämpningar. Den interna dataloggern är helt konfigurerbar och har utvecklats för att samla in och visa data från ECU:n, med över 1 000 helt kompatibla ECU-protokoll.\u003c\/p\u003e  \u003cp\u003eVåra Formula-hjul finns i en mängd olika storlekar (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca title=\"Aim SW4 GT320\/GT350 Formula Steering Wheel\" href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-formula-steering-wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003eDe kompakta versionerna 270 och 280 är det perfekta valet för ensitsiga bilar eller sportprototyper där utrymmet i förarhytten är begränsat. Skillnaden mellan Formula-rattarna 4 270 och 280 är den totala diametern: 280 är 10 mm större för att passa olika förarpreferenser.\u003c\/p\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e SW4 270\/280 Formula-ratten är också helt kompatibel med vår PDM32 via CAN-kommunikation.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_cy4Jzy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel anslutning\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eAnsluta \u003ctc\u003eAim\u003c\/tc\u003e Att koppla 270\/280 Formula-ratten till din ECU är enkelt. Du kan sampla dussintals kanaler direkt från ECU:n med en enda anslutning, istället för att installera flera analoga sensorer.\u003c\/p\u003e  \u003cp\u003eData som samplas beror på vilken ECU som används, men inkluderar vanligtvis varvtal, motorbelastning, gasspjällsläge (TPS), olje-, luft- och vattentemperaturer, oljetryck, batterispänning, hastighet, växel och lambdavärden (luft\/bränsleförhållande). Listan över tillgängliga ECU-drivrutiner uppdateras och uppgraderas ständigt och innehåller över 1 000 olika ECU:er.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgång kan du skicka meddelanden direkt till ett befintligt CAN-nätverk, vilket möjliggör utökad integration med andra fordonssystem.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_E8RKHy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eVisa \u0026amp; Tryckknappar\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formelratten 4 270\/280 är utrustad med en högkontrast 4.3\" TFT-display, helt konfigurerbar och avläsbar i solljus. Med 8 växlingsljus, 4 RGB-larm-LED och en integrerad omgivningsljussensor ger ratten alltid tydlig, exakt och tillförlitlig information direkt till föraren.\u003c\/p\u003e  \u003cp\u003eFormula-ratten 4 270\/280 har 10 tryckknappar och 3 vridbrytare, alla bakgrundsbelysta med RGB-lysdioder. Den har även avtagbara handtag, vridbrytare och ett brett utbud av ECU- och CAN-anslutningsmöjligheter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_nAJYLi\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFlexibla larm\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e SW4 270\/280 Formula-ratten har 8 konfigurerbara RGB-lysdioder för växlingsljus och 4 konfigurerbara RGB-lysdioder för larm. Du kan definiera villkor, färger, prioriteter och blinkfrekvenser, samt visa medföljande textmeddelanden vid behov.\u003c\/p\u003e  \u003cp\u003eDe avancerade RGB-växlingsljusen i flera färger kan anpassas helt, med möjlighet att definiera olika växlingsmönster för varje växel.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_9enpXA\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eTillvalstillbehör\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDet finns ett brett utbud av tillbehör för att du ska få ut det mesta av din ratt:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003ca title=\"Aim GPS09 Module\" href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\"\u003e\u003cstrong\u003eGPS-modul\u003c\/strong\u003e\u003c\/a\u003e:  GPS-modulen är ansluten via CAN och gör det enkelt att mäta varvtid och spårposition.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eKopplingspaddlar\u003c\/strong\u003e:  Vänster\/höger kopplingspaddlar kan läggas till från tillbehören högst upp på sidan för att passa din körstil.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eAndra expansioner\u003c\/strong\u003e:  Utöka ditt system med en rad ytterligare funktioner \u003ctc\u003eAim\u003c\/tc\u003e enheter, inklusive TC Hub, Lambda Controller, SmartyCam 3, RIO, GS-Dash och fler.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270 mm Artikelnummer: X07SW42700\u003c\/p\u003e  \u003cp\u003e280 mm Artikelnummer: X07SW42800\u003c\/p\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45624512282726,"sku":"SN 8401640 \/ 8401639","price":2160.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SW4270.png?v=1779097526","url":"https:\/\/www.aimshop.com\/sv\/products\/mal-sw4-280-formel-ratt-3","provider":"AimShop.com","version":"1.0","type":"link"}
