Gå till produktinformation
1 av 1
Revotec Aluminium Hose Adaptor Motorcycle
SKU: REV-25-18-B
Vanligt pris
£20.00
Vanligt pris
Försäljningspris
£20.00
The Revotec Aluminium Hose Adaptors are designed to insert into a water hose to provide a take-off for a water temperature gauge sender or fan controller.
Inserts into waterhose Provides takeoff for water temperature sender
Range of sizes & threads available
The Revotec Aluminium Hose Adaptors are designed to insert into a water hose to provide a take-off for a water temperature gauge sender or fan controller. A screw-in barbed take-off is available separately to convert to a T piece.
High-quality hose adaptor CNC machined from aluminium.
Available in different diameters and M10 x 1.0mm thread or 1/8 NPT thread with milled flat for sensor seal
The overall length of the adaptors is 75mm, with a tread section length of 25mm.
  • Hose Adaptors available in the following sizes:
  • 25mm
  • 28mm
  • 30mm
  • 32mm
  • 35mm
  • 38mm
  • 45mm
  • In either M10 or 1/8NPT
  • Overall length: 75mm
  • Thread section length: 25mm
  • Revotec Aluminium Hose Adaptor - Whichever chosen at checkout
  • 25mm
  • 28mm
  • 30mm
  • 32mm
  • 35mm
  • 38mm
  • 45mm
