Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim SmartyCam U Bolt Mount - AimShop.com
    SM-UB
    I lager, redo att skickas
    £60.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £60.00
    The SmartyCam can be installed using the U bolt mount. It is suitable for SmartyCam HD, Sport & Corsa.
    Secure mounting for SmartyCam 2.1, 2.2 & 3
    Ball & socket system
    Suitable for 0.5 to 1.2"
    SmartyCam HD Compatible
    SmartyCam 3 Sport Compatible
    SmartyCam 3 Corsa Compatible
    The Aim SmartyCam U Bolt mount allows you to mount your SmartyCam to your car/motorcycle.
    The mount has been designed to mount to a roll bar, railings, or tubes that have a diameter of between 0.5 to 1.2 inches. The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
    The mount is adjustable, once you have the camera in the optimal position to capture the best footage you just need to tighten the lever to secure the camera in place.
    U Bolt Mount
    Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2 inches.
    For use with SmartyCam HD, Sport & Corsa (2.1, 2.2 & 3).
    • 1 U-Bolt and straps
    • 160mm single ball arm
    • 1 Ball head
    • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
    Technical Sheet Race Studio 3
    • Öppnas i ett nytt fönster.
