Yamaha YZF-R6 Motorcycle Aim Solo 2 DL & SmartyCam 3 GP Plug & Play Track Day Kit
SKU: SOLO2-K-YAM-4-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256920CS-X47SOLO2DL02
- Vanligt pris
- £2,210.00
- Vanligt pris
- Försäljningspris
- £2,210.00
A Powerful Track Day Combination
The Yamaha ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Please Note: For these models/years, Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
Plug & Play Compatibility
Yamaha YZF-R6 (YEC included) - 2004-2005
Why Choose The Solo 2 DL For Yamaha YZF-R6 Motorcycles
Solo 2 DL Key Features
Precise Lap Times
Aim Solo 2 DL is the most precise GPS lap timer there is with the ability to show you your lap time live as you drive. Receiving data from two satellite constellations from anywhere on the globe by using GPS and Glonass also giving you a significant improvement in data speed and positioning precision.
Solo 2 DL Track Database
Why Choose The SmartyCam 3 GP For Yamaha YZF-R6 Motorcycles
SmartyCam 3 GP Key Features
Automatic Start/Stop
Yamaha YZF-R6 Aim Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
- Display: Graphical
- Backlight: 8 configurable RGB colours
- GPS: 25 Hz
- External power: 12 V
- Memory: 4 GB
- SmartyCam 3 GP
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam 3 GP - Bullet Cam
- External CAN cable 2m
- External power cable
- Yamaha YZF-R6 Plug & Play connection cable
- Bracket
- 2 spacers
- 2 self-locking nuts M6
- 2 washers M6
- 4 washers M6
- 2 self-locking nuts M4
- 2 washers M4
- 2 Allen screws with rounded head M6 x 60mm
Precise Lap Times
- GPS: 25 Hz
- Memory: 4 GB
- SmartyCam 3 GP
- Video Out: 3G-SDI
- Solo 2 DL
- Bracket
- 2 spacers
- 2 washers M6
- 4 washers M6
- 2 washers M4
