Fuel Pressure Sensor 1/8 NPT 0-15 PSI
The Aim Pressure Sensor is suitable for brake, oil, fuel and water pressure readings, reading pressures up to 15 PSI. This pressure sensor measures exactly how much pressure passes through.
Why Choose the Aim 0-15 PSI Fuel Pressure Sensor
The Aim 0-15 PSI Pressure Sensor is available in 1/8 NPT and is fitted with a 4-pin 719 male binder connector to suit Aim loggers, dash loggers, lap timers and dash displays. Many aspects affect various engine pressures, so knowing your engine has the correct amount of pressure is paramount to longevity and performance.
If there is a pressure change, incorporating a pressure sensor into your setup will allow it to be detected and signalled to prevent the worst. You can see through live telemetry about what’s happening as the sensor turns the physical force of fluid pressure into a predictable electrical signal that can be monitored to protect your engine.
How a Pressure Sensor Works
The Aim Pressure Sensor is installed directly into the fluid or air line of the system being monitored. Inside the sensor is a sensitive internal component, typically a thin diaphragm.
As the system generates pressure, whether from a pump, a mechanical piston, or compressed air, that pressure forces the diaphragm to flex or bend. The sensor precisely measures the degree of this movement and converts that physical displacement into an electrical voltage signal:
  • Low Pressure (0 PSI): The sensor outputs its minimum voltage, typically 0.5 Volts (V).
  • High Pressure (15 PSI): The sensor outputs its maximum voltage, typically 4.5 Volts (V).
This is a linear scale. This means if the pressure is exactly halfway (7.5 PSI), the voltage will also be exactly halfway between 0.5V and 4.5V (which is 2.5V). This electrical signal is what the vehicle’s data logger or ECU (Engine Control Unit) translates back into a pressure reading for you to see.
The Aim brake, oil, fuel and water pressure sensor is available in PSI or Bar variants
The pressure sensor allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in motorsport.
The Aim brake, oil, fuel and water pressure sensor is available with terminated and unterminated connectors for compatibility with external manufacturers
We also offer unterminated sensor that are designed to work seamlessly with Bosch, MoTeC, Cosworth, or other manufacturer hardware, making it easy for you to integrate the reliable and efficient Aim Pressure Sensors into any setup.
The Aim brake, oil, fuel and water pressure sensor is expandable with ACC3, Aim displays and display loggers, XLog, Data Hub and more
You can expand your system with a range of products from the ACC3 Analogue CAN Converter, Displays and Loggers, Data Hubs and more.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Burst Pressure: 3 x rated pressure
  • Temperature Working Range: -20°C to 135°C
  • Waterproof Rating: IP67
  • Housing: 316 stainless steel
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 1/8 NPT
SKU: S-P-NPT-15
Part Number: X05PSA00015P18K
Oil/Fuel Pressure Sensor 010 Bar Diagram
Pressure sensor pinout
Pressure Sensor Tech Sheet
