Aim 712-712 كابل توصيل CAN EXP من ذكر إلى ذكر بخمسة دبابيس
Connect Your System
The Aim 712-712 patch lead is a durable extension cable with 5-pin male connectors designed for connecting devices or expanding existing wiring in your Aim data system. These cables use the metal Binder 712 screw-on connectors with 5-pins in the housing, ensuring reliable signal transmission.
Why Choose the Aim 712-712 Patch Lead
The Aim 712-712 patch lead simplifies installation and setup, allowing easy connection between modules, expansion hubs, or sensors without complex rewiring. It’s ideal for clean, organised wiring layouts.
The 5-pin male to male lead is available in multiple lengths and is compatible with Aim systems such as Channel Expansion Hubs, ECU Bridge, Lambda Controller, GPS Module, Data Hub, and display/logger harnesses. Essentially, the 712-712 patch lead is used to extend your connections or integrate additional modules, ensuring flexibility and reliability across your Aim racing setup.
Note: Aim CAN cables link modules or hardware on the Aim-specific CAN system (Controller Area Network). These cables transfer data or power from one Aim component to another. It should not be confused with the CAN system in your vehicle's factory wiring. They are separate CAN systems. Only in specific cases will an Aim CAN component interface with a vehicle CAN component, such as linking vehicle ECU data to a data logger.
712-712 ذكر لذكر تصحيح الرصاص
