انتقل إلى المحتوى
تسجيل الدخول
يبحث
عربة التسوق
  • متابعة التسوق
    إطلب تعليمات خاصة
    المجموع
    عرض عربة التسوق
    يبحث
    Laser Etched inserts for AiM CAN Expansion K Keypad - AimShop.com
    K-I-
    Aim CAN Keypad Laser Etched Inserts
    £1.70
    • شارك على الفيسبوك
    • شارك على الواتساب
    • فيسبوك شارك على الفيسبوك
    • واتساب شارك على الواتساب
    £1.70
    ALL CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL
    We have an extensive range of laser-etched inserts available to suit any function applications required on your keypad.
    We offer an extensive range of 15mm laser-etched inserts designed for our Aim CAN Keypad. Our wide range is available to suit any function applications required.
    Please select as many inserts as you wish and add them to your cart.
    Key Features:
    15mm laser-etched inserts Large range available
    Durable & removable Spares
    Customise Your Keypad
    With a fully customisable keypad, you can choose the application that's right for you. The inserts are also easily substituted without having to take apart the keypad.
    Customise your keypad in many applications such as lights, boost, heating & fans, wipers and engine control. The list is endless.
    • Inserts: Laser Etched
    • Size: 15mm
    • Laser-etched insert
    • The amount depends on what is selected at checkout
    • يفتح في نافذة جديدة.
