Aim DTA S60 Interface Lead MXL Evo
Connect Your System
The DTA 660 ECU Interface Lead is a cable that allows you to easily connect your ECU to your Aim data logger. It has been specifically designed to withstand the intense rigours of the motorsport environment.
Once connected, the logger displays (and/or records, depending on the logger on the ECU data stream and configuration) values like RPM, engine load, throttle position, air and water temperatures, battery voltage, speed, gear, lambda value (air/fuel ratio) and analogue channels.
DTA S60 Interface Cable
