Aim Dual Brake Pressure T-Piece Mount
Mount Your System
The Aim Dual Brake Pressure T-Piece Mount is designed to mount 2 M10 brake pressure sensors into 1 hydraulic line, with each sensor featuring a 719-type plastic binder connector compatible with Aim systems and extension leads.
Why Choose the Dual Brake Pressure T-Piece Mount
The Dual Brake Pressure T-Piece Mount is ideal for motorsport use, allowing you to monitor both front and rear brake circuits or dual master cylinder setups with a single compact fitting. The T-piece provides insight into brake pressure, braking points (start and finish), driver alertness and overall brake system status, offering detailed data for performance and safety monitoring.
حامل على شكل حرف T لضغط الفرامل المزدوج
