Aim ECU Log Racing Data Logger
Choose Accessories
Compact Data Logger
The Aim ECU Log is a compact, lightweight, and waterproof data logger designed to record essential performance data directly from your vehicle’s ECU. With its ultra-small size, it’s ideal for motorcycles, karts, or vehicles with limited installation space.
Why Choose the ECU Log
The ECU Log is designed for those who want simple but powerful ECU data recording in the most compact form. With its ability to integrate with Aim expansions, GPS modules, and cameras, the ECU Log transforms into a versatile performance monitoring system.
ECU Log Connectivity
The ECU Log ensures flexible data acquisition for a wide range of applications:
- ECU Connection: Compatible with thousands of predefined CAN, K-Line, or RS232 protocols.
- Expansions: Connect to Aim modules such as ACC3 (analogue inputs), LCU-One Lambda controller, or SmartyCam 3.
- Storage: 4GB internal memory plus a removable USB-C key for easy transfer.
GPS & Inertial Platform
While the ECU Log itself focuses on ECU data, it integrates seamlessly with expansions for broader functionality:
- GPS09c Module (optional): Adds 25Hz GPS data for lap timing, track position, and speed.
- Inertial Data: Expandable to include 3D accelerations and gyro data via the Aim ecosystem.
Compact, Durable Design
Measuring just 61 × 44 × 27 mm, the ECU Log is the smallest logger in the Aim lineup. Its IP65-rated housing protects against dust and water spray, making it suitable for both motorcycles and motorsport applications where durability is crucial.
Analyse with Race Studio 3
Data captured by the ECU Log can be quickly transferred via USB-C and analysed in Aim’s Race Studio 3 software. Use professional tools such as histograms, scatter plots, GPS maps, and synchronised video (with SmartyCam) to gain a complete picture of your performance.
ECU Log data logger is built to scale with your needs:
- ACC3 Analogue Input Module: Add pressure, temperature, or suspension sensors.
- LCU-One Lambda Controller: Log air/fuel ratios and exhaust data for engine tuning.
- SmartyCam: Overlay ECU and expansion data directly onto HD video.
In Summary
The Aim ECU Log is a small but powerful way to capture ECU data and expand into a full data logging system when needed. Whether installed on a motorcycle, kart, or compact racing vehicle, it provides the essential data foundation for serious analysis in the smallest possible package.
ECU Log
Mini USB Drive 16GB
Your Chosen Harness
USB A – USB C Cable
