تخطي إلى معلومات المنتج
1 من 3
Aim EVO4s Downhill Mountain Bike Data Logger Kit
SKU: EVO4S-MBIKE-KIT-200-75
£1,720.00
£1,720.00
The Evo4s Downhill Racing Data Logger Kit offers a lightweight, full data logging facility for improving bike and rider performance. Suspension Sensor options included.
The Kit includes Aim EVO4s Data Logger, 2 x patch leads to connect everything together, 1 x Lightweight Lipo Battery and a Hall Speed sensor. There is the additional option of our superb video logger the Smartycam 84 Bullet camera which will show all your data on a video for superb analysis of your performance.
The new powerful and flexible Evo4s Downhill Bike Racing Data Logger is the evolution of the well known Aim EVO4. It maintains the same connection logic, one connector per channel, but with a completely redesigned internal electronic board, fully compatible with the last generation of Aim dash loggers and with the new powerful Race Studio 3 software.
The Aim EVO4s Data logger is the new powerful and flexible data logger, an evolution of the well-known EVO4. It maintains the same one connector per channel connection logic, but with a completely redesigned internal electronic board. Aim EVO4s are fully compatible with the last generation of Aim dash/displays and with the new powerful Race Studio 3 software.
A wide range of sources for your data
The EVO4s Mountain Bike Data Logger samples all the information you need from your bike sensors.
Sensors
Mountain Bike Suspension Potentiometers are available for the Front 200mm, and 250mm and for the rear 75mm and 100mm. Used to measure the displacement between two points using a sensor (linear potentiometer) directly connected to the points of measure. This potentiometer can measure linear displacements like dampers compression or extension and steering rotation measured through the rack displacement
Installation details
more info
Internal three-axial accelerometer and gyro sensor
A built-in inertial platform lets you have the most powerful system for understanding oversteering, understeering, banking, etc.
Aim EVO4s GPS08 Module
GPS technology represents a true revolution in racing data acquisition. Now, thanks to GPS08 Module and Race Studio 3 software, as soon as you start your track session you can immediately sample lap and split times as well as speed, position and acceleration… all the information needed for improving your riding technique.
GPS 08 is more precise than most of the existing GPS systems, as it has been designed to add to the GPS satellite’s signal the Global Navigation Satellite (Glonass) system’s signal. With an average of almost twenty satellites working in conjunction, GPS 08 guarantees a precision and a reliability simply not comparable to the old generation GPS systems
The GPS 08 Module included in the Aim EVO4s kit, provides the following information, updated ten times per second:
  • Position (latitude, longitude, altitude)
  • Speed
  • Longitudinal acceleration
  • Lateral acceleration
If EVO4S knows the finish line of the track and the split coordinates, it can calculate and show:
  • Lap Times
  • Split times
    GPS08 is more precise
    Digital Output
    EVO4S features a 1 amp at 12 volts digital output. You can configure it in order to turn it on or off depending on the value of the analogue or digital inputs, expansion values, GPS information or math channels.
    more info
    Download your EVO4s data to a pc for professional data analysis.
    Data recorded by EVO4s can be downloaded to PC and analysed with the professional Race Studio Analysis software graphs, histograms and tables will help you evaluate your performance, providing objective support to avoid mistakes and improve your driving technique.
    • EVO4S samples all the information you need: data coming from your vehicle ECU via CAN, RS232 or K-line, from the internal accelerometers and gyro, from the GPS08 Module included in the kit.
    • Completely re-designed internal board
    • 5 analogue channels with configurable 12 bit 0-5 Volt, 0-500 mV, 0-50 mV inputs or thermocouple input, used to sample data coming from temperature, pressure, suspension and other kinds of sensors.
    • 2 speed inputs, which allow monitoring of the different wheels' behaviour.
    • 1 RPM input, which manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command (low voltage).
      Technical Specifications
      LEDs: 1 system status
      CAN connections: 2
      ECU connections: CAN, RS232 or K-Line
      ECU compatibility: + 1,000 industry leading ECUs
      Expansion CAN connection: GPS, Channel Expansions, Thermocouple Expansions, Lambda Controllers, SmartyCam HD
      Analogue inputs: 5 fully configurable, max 1,000 Hz each
      Digital inputs: 2 Speed inputs, lap signal, coil RPM input
      Digital outputs: 1 (1 Amp max)
      Internal memory: 4 GB
      Body: Anodized aluminium
      Connectors: 13 Binder connectors
      Dimensions: 130 x 35 x 46.6 mm
      Weight: 330 g
      Power consumption: 350 mA
      Waterproof: IP65
      In The Box
      • Evo4s Downhill Bike Racing Data Logger Kit
      • Harness
      • GPS08 Module
      • 2 x patch leads to connect everything together
      • 1 x Lightweight Lipo Battery
      • Hall Speed sensor.
        User manual ver. 1.02
        Technical sheet ver. 1.06
        Pictures
