The Ultimate Rider Setup
Combine the XLog, a small, waterproof, 25Hz GPS data logger; the ACC3, our unbeaten Analogue CAN Converter; Suspension Potentiometers; M10 0-100 Bar Brake Pressure Sensors, and you can even connect the ultimate motorcycle camera - the SmartyCam 3 GP, to become the best rider and beat your best lap times.
Why Choose the XLog Motorcycle Kit
It provides a powerful solution for anyone who wants to capture and analyse their performance data without needing an on-board display. Combined with the ACC3, Suspension Potentiometers and M10 0-100 Bar Brake Pressure Sensors, you will find the ultimate key to control, analysis and improvement.
AiM Motorcycle XLog motorcycle data logging kit with compact black data logger unit
XLog datalogger on motorcycle setup
XLog Features
  • Lap times
  • Sector times
  • Vehicle position and speed
  • 3D acceleration and gyro
  • ECU data via CAN, K-Line or RS232 connections.
    (You can select the protocol of your car/bike among thousands of pre-defined protocols, or easily develop your own).
  • Digital RPM input from the primary of the coil (150-400V) or from a square wave (8-50V) when no ECU connection is available.
In addition, the XLog features a second CAN for connecting external device or Aim Expansion, meaning you can add a Lambda Controller, analogue inputs, and a professional motorsport camera for enhanced functionalities.
Brake pressure sensor is available in PSI or Bar variants
0-100 Bar M10 Brake Pressure Sensor & Banjo Bolt Adaptor
The M10 0-100 Bar Brake Pressure Sensor allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in motorsport.
The Brake Pressure Sensor comes with a Double Banjo Bolt M10 Adaptor which allows for easily installation. It fits neatly into existing hydraulic systems and has a high-quality construction for durability and leak-free performance.
Like all Aim devices, the Aim ACC3 is built for motorsport applications. Its compact design ensures easy installation across a range of racing vehicles, while its robust construction guarantees reliability in demanding environments.
Managing up to 4 channels at 200Hz each, the ACC3 allows you to capture and analyse additional sensor data with precision.
When combined with Race Studio 3 software, the ACC3 unlocks powerful configuration and analysis tools, including suspension analysis with Aim Eclipse sensors and video synchronisation with SmartyCam 3 cameras.
Inertial Platform in XLog
XLog GPS & Inertial Platform
  • Lap Timing & Sectors: Automatically recognises track layouts, samples laps and sectors, and provides all the raw data for Race Studio 3 analysis.
XLog connects with Race Studio software
XLog Connectivity
  • ECU Connection: Supports thousands of predefined CAN, RS232, or K-Line protocols, or you can build your own protocol via CAN builder.
  • Second CAN Option: Configure for Aim expansions, or connect additional sensors and third-party CAN devices.
  • Wireless: Integrated Wi-Fi and Bluetooth for fast, cable-free data transfer.
  • USB-C & Memory Key: 4GB internal memory plus a removable 16GB USB-C key for quick access.
Compact, Durable Design
Analyse with Race Studio 3
The XLog data logger works seamlessly with Aim’s ecosystem of devices thanks to its second CAN connection.
The second CAN option can be used for Aim Expansions or to connect sensors and other devices that communicate via CAN and use existing protocols or create a dedicated protocol for the second CAN.
  • ACC3 Analogue to CAN Converter: Add up to four analogue channels for pressure, temperature, suspension, and other sensors.
  • LCU-One Lambda Controller: Capture air/fuel ratios and exhaust data for tuning and performance optimisation.
  • Data Hub: Split EXP ports to connect multiple expansions such as GS-Dash displays, Lambda controllers, or additional converters.
XLog
  • USB Connection: Yes
  • GPS: 25Hz
  • Wi-Fi: Built in
  • Bluetooth: Built in
  • Expansions: ACC3, Lanbda Sensors, SmartyCam
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • External Power: 9-15V
  • Weight: 150g approx.
SKU: XLOG
ACC3
  • Connection: CAN
  • Material: PA6 30% glass
  • Weight: 50g
  • Waterproof: IP65
SKU: ACC
ACC3 pinout
  • XLog data logger
    XLog
  • AiM ACC3 Analogue CAN Converter front view with compact black housing and labeled connectors
    ACC3
  • Aim Sensors steering angle sensor for car racing suspension systems
    ×2 مقاييس فرق الجهد للتعليق
    محول مستشعر ضغط الفرامل
  • مستشعر الضغط M10
  • AiM XLog motorcycle data logging kit for tracking and analyzing motorcycle performance data
    كابلات التمديد
  • ACC3 4-Channel Harness
XLog User Guide
XLog Tech Sheet
دليل مستخدم لجنة التنسيق الإدارية
ACC Tech Sheet
Rose End Tech Sheet
Pop End Tech Sheet
Pressure Sensor Tech Sheet
