Mount Your System
The Aim Bar Pad Mount secures any Aim Solo 2 GPS Lap Timer to the handlebars, so that you can easily and accurately measure your lap times. It is predominantly designed for motocross handlebars, but can also fit standard motorcycle and off-road vehicle handlebars with or without a cross brace.
Why Choose the Aim Solo 2 Bar Pad Mount
Designed specifically for the Aim Solo 2 and Solo 2 DL, the bar pad provides a strong and secure mounting solution, ensuring the lap timer won’t move, fall or cause any distractions to the rider. It comes with a transparent protective cover, a shock-protected Solo 2/2DL unit mount, a fixing bracket and 4 x 12mm M3 screws, ensuring that your lap timer is protected against the harsh environment of off-road riding.
Please Note: The Solo 2 is not included, the image is to show what the bar pad will look like when fitted with a GPS lap timer.
  • Bar pad for Solo 2 & Solo 2 DL lap timers
  • Available with or without cross brace
  • Transparent protection cover
  • Comes with 4 x 12mm M3 screws
Bar Pad with Cross Brace SKU: SOLO2-PD / Part Number: X47KPSOLO2T20
Bar Pad without Cross Brace SKU: SOLO2-PD-WB / Part Number: X47KPSOLO2T10
  • AiM Solo 2 & Solo 2 DL Bar Pads - AimShop.com
    Chosen Solo 2 Bar Pad
    Transparent Protective Cover
  • Bar Pad Mounting Bracket
  • Bolt icon
    4 x 12mm M3 Screws
Bar Pad with Cross Brace Installation Guide
Bar Pad without Cross Brace Installation Guide
