Aim SmartyCam Bullet Camera Roll Cage Mount
Mount Your System
The Aim SmartyCam Roll Cage Mount is the simple and secure solution to mounting your SmartyCam Bullet Camera to your vehicle. It is suitable for the SmartyCam 2.1, 2.2, 3 and 4 Dual and GP models.
Why Choose the Bullet Camera Roll Cage Mount
The Aim SmartyCam Bullet Camera Roll Cage Mount is the most secure and easiest way to secure your SmartyCam Bullet Camera when you’re on the track in your vehicle. The clamp is simple to attach, suiting a variety of roll cage diameters for the perfect setup. The ball and socket system allows you to move the positioning around quickly and easily, giving you maximum visibility for post-session reviews.
رصاصة الكاميرا لفة قفص جبل
