انتقل إلى المحتوى
تسجيل الدخول
يبحث
يبحث تسجيل الدخول عربة التسوق 1
عربة التسوق
أنت مؤهل للحصول على الشحن المجاني.
  • AiM Solo 2 GPS track day racing lap timer for cars, front view
    Aim Solo 2 GPS Track Day Racing Lap Timer
    £365.00
    إزالة
إطلب تعليمات خاصة
المجموع
£365.00
عرض عربة التسوق
يبحث
AiM Accessories SmartyCam 3 bullet camera replacement spare part
AiM Accessories SmartyCam 3 Bullet Camera replacement spare close-up
AiM Accessories SmartyCam 3 Bullet Camera replacement spare product image
AiM Accessories SmartyCam 3 bullet camera replacement spare part, compact black camera housing
AiM Accessories SmartyCam 3 Bullet Camera replacement spare shown from the side
لSmartyCam Dual & GP
الاستبدال أو الغيار
Choice of Lens
Compact & Lightweight
SM3-BC
Aim SmartyCam 3 Bullet Camera Replacement
£315.00
الاستبدال أو الغيار
Choice of Lens
  • شارك على الفيسبوك
  • شارك على الواتساب
  • فيسبوك شارك على الفيسبوك
  • واتساب شارك على الواتساب
£315.00
The Aim SmartyCam 3 replacement Bullet Camera is a lightweight, robust replacement or spare part for your camera kit.
High-quality camera Replacement for SmartyCam 3
Compact & robust Lens options 67°, 87°, 120°
Replacement Bullet Camera
The Aim replacement bullet camera has been designed for motorsport and is incredibly light and robust.
The bullet camera is black anodised, billet machined, small and compact enough to fit into the tightest of locations.
Ideal to have one spare at the track in case your camera gets damaged.
If you have multiple vehicles, you can have the correct lens for each specific vehicle.
Provides high-quality footage.
Lens Options
The replacement bullet camera is available in three lens versions.
The 67° lens is preferred for closed-roof cars, as it sees the track just within the windscreen pillars.
The 87° lens is available for open roof and formula cars where it is possible to have a more ample view of the track.
The 120° lens gives an even wider view of the track and surroundings.
Please Note: This replacement Bullet Camera is for the SmartyCam 3.
We also have Bullet replacement front glass kits available in three different lens applications.
These are some of the items that can be added to your vehicle for incrementing performance and data.
  • Anodised black
  • Billet machined
  • Available in 67°, 87°, 120° lens
  • 1 x Replacement Bullet Camera
  • Lens option available 67°, 87°, 120°
  • الأسئلة الشائعة
  • برمجة
  • فيديوهات الدعم
  • دليل المنتج PDF
  • اتصل بنا
  • كن سفيرا
  • الإصلاحات
  • دعم الدردشة المباشرة &
  • يفتح في نافذة جديدة.
