Aim Solo 2 DL Motorcycle Plug & Play Data Logger
Choose Accessories
Upgrade your riding setup with one of the best motorcycle lap timers in the industry — the Solo 2 DL GPS lap timer. Display instant speed, timing splits, live data and predictive lap times on a high-contrast display with an accuracy of up to two-hundredths of a second.
Why Choose the Motorcycle Solo 2 DL
Building on the features of the Aim Solo 2 model, the Solo 2 DL motorcycle lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Plug & Play Compatibility
This Solo 2 DL Kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model. Plug & play is currently available for the following bike models:
- Aprilia RSV4 RR/RF, 1100, TUONO V4
- Aprilia RSV4 RR/RF, 1100, TUONO V4 RR
- BMW S1000RR, S1000RR HP4 (2009 -2019)
- Ducati Panigale, 899, 959, 1199, 1199R, 1299 & V4 (2012 -2020)
- Ducati 848, 1098 & 1198 (2007 - 2013)
- Euro 5 Models (All Manufacturers)
- Kawasaki ZX-10R (From 2011)
- MV Agusta F3 675, 800 & F4 (From 2012)
- Suzuki GSX-R 600, 750, 1000 (2001 -2019)
- Yamaha YZF-R1/R1M (FROM 2015) & YZF-R6 (From 2017)
- Yamaha YZF-R1 (2004 - 2008) & YZF-R6 (2006 - 2016) - YEC Included
- Yamaha YZF-R1 (2009-2014) - YEC Included
- Yamaha YZF-R6 (2004 - 2005) - YEC Included
Please select your model before adding the Solo 2 DL Plug & Play Kit to your cart.
The Solo 2 DL motorcycle lap timer has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the bike lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you ride past.
The Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
One of the many reasons that the Aim Solo 2 lap timer is regarded as one of the best GPS lap timers in the motorsport industry is due to its easy configuration and integration with Race Studio 3 software.
- Create, modify and manage configurations for a customised display
- Perform in-depth data analysis to compare lap times, sector performance and more
- Overlay data performance data onto your SmartyCam video footage for post-race review
- Access the extensive track database within Race Studio 3 to ensure accurate lap timing and data logging
- Save new track layouts directly from Race Studio for future sessions
Mounting Options
Solo 2 DL
Power Cable with AC Adapter
Your Chosen Connection Cable
