Aim Solo 2 DL Plug & Play Cable for Microtec Motocross ECU
Connect Your System
The Aim ECU Plug & Play Cable has been specifically optimised for dirt bikes and is for use with the Solo 2 DL Lap Timer. The ECU cable is compatible with the Microtec M222 ECU and the Microtec M206 ECU, making it an ideal solution to log your ECU data.
Why Choose the Aim Solo 2 DL Plug & Play Cable
The Aim Solo 2 DL Plug & Play Cable suits a range of Microtec motocross ECUs, allowing you to easily connect to an Aim Solo 2 DL Lap Timer via a secure 712 7-pin male binder connector. Designed specifically for dirt bike environments, this ECU cable is made from high-quality, long-lasting materials, so you can rely on your setup during track days and get your data whenever you need it.
Plug & Play Compatibility
This Solo 2 DL Plug & Play Cable is compatible with the following Microtec motocross models:
- Microtec M222 ECU
- Microtec M206 ECU
If you are unsure whether this ECU cable will fit your motocross bike, don't hesitate to contact our team.
كابل Solo 2 DL Microtec ECU
