The Advanced Handlebar Switch 2
The Handlebar Switch 2 (HBS2) is a second generation compact, high-performance, ergonomic handlebar switch by Aim.
If you're looking for a highly flexible switch for your handlebars, HBS2 offers a complete solution with 4 push buttons and 11 integrated LEDs.
Why Choose the Handlebar Switch 2
You can activate traction control with the HBS2 to stop your wheels from spinning when you apply any excess power. The Handlebar Switch 2 can also be used to activate launch control, which will assist you to accelerate from a standing start.
Up to 5 Selectable Maps
Taipan ECUs can manage up to 5 maps, and these maps can be selected by OEM switches, such as Honda, Husqvarna, and KTM. The Handlebar Switch 2 makes this far easier!
Taipan ECUs and HBS2 are fully compatible with all the stock handlebar switches. Plus, HBS2 allows the management of quick shifting on factory-equipped bikes.
  • Connector: 1 JST 04T-JWPF-VSLE-S waterproof connector for CAN BUS communication
  • PA6 + 30% glass fiber + silicon rubber
  • Dimensions: 43.2 x 27.1 x 38.0mm
  • Weight: 70g
  • IP67
SKU: HBS2
Part Number: XE1HBS200
HBS2 Tech Sheet
