Tyre Temperature Sensor Bracket Kit
The Aim tyre temperature sensor bracket kit is a dedicated kit to ensure the secure mounting and installation of Aim tyre temperature sensors.
Why Choose the Tyre Temperature Sensor Bracket Kit
The Aim tyre temperature sensor bracket kit includes 4 brackets and fittings, enabling the optimum mounting of the sensors in the correct place to get accurate temperature readings from all 4 tyres.
Spare sensors are ideal if you want to add a spare set of wheels for testing purposes or mid-race tyre changes. As such, 712-719 4-pin patch leads are also available to purchase if reserves are required.
Bracket Installation
When installing the tyre temperature sensor brackets, ensure that the sensors are installed away from strong heat sources - like the exhaust gas pipe - and keep away from electromagnetic interferences.
Please refer to the documents in the ‘Free Downloads’ tab for all information, including images, diagrams on how to fit the sensors to the brackets.
  • Front right, front left, rear right & rear left brackets
  • 6x M6 x 25mm screws
  • 8x M3 x 10mm screws
  • 2x M5 x 20mm screws
  • 4x M5 x 50mm screws
  • 10x M6 nuts
  • 2x M5 nuts
  • 4x silent blocks
  • 8x grover washer 3mm hole
  • 2x washer 5mm hole
  • 10x washer 6mm hole
  • Please refer to the user guide on how to install the tyre temperature brackets
SKU: S-TT-BK
Part Number: X90KSTTS0
  • أضرار L & R الأمامية
  • أضرار L & R الخلفية
  • 2x وصلات دوارة
  • 2x نصف قذائف معدنية
  • 2 × أغطية نصف بلاستيكية
  • 2 × دعامات أمامية
  • Bolt icon
    مسامير & صواميل
  • Washer icon
    غسالات
دليل مستخدم مجموعة أدوات استشعار درجة حرارة الإطارات
دليل المستخدم لدعامات مستشعر درجة حرارة الإطارات
