Mount Your System
The Aim Honda Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for the Solo 2 and Solo 2 DL GPS Lap Timers. The bracket is supplied with all the necessary hardware required for fitting the product to your motorcycle.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket has been specifically designed for securely mounting the lap timer onto Honda CBR 600RR motorcycles. As all components are included to set it up, it provides a quick and stress-free installation.
Please Note: The bracket is only compatible with the CBR 600RR original triple clamp.
Honda CBR Motorcycle
Plug & Play Cable
A separately sold plug & play cable is also available for the following Honda motorcycle models and years:
  • CBR 600RR - 2003-2019
  • CBR 600RR HRC with D11 marked ECU - 2013-2015
  • CBR 1000RR - 2004-2016
  • CBR 1000RR HRC - 2014-2016
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Honda CBR 600RR original triple clamp motorcycles only
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: HON-B
Part Number: X46KSHCBR6
  • هوندا سولو 2/2 DL قوس
  • ×1 برغي ألين برأس مستدير M6x60mm
  • ×2 براغي ألين ذات رأس مسطح M4x10mm
  • ×1 غسالة مسننة
  • ×1 وتد مطاطي
Honda CBR User Guide
