Link Crank Angle Sensor
The Link crank angle sensor (CAS) works with a trigger wheel to accurately measure crankshaft position, a critical input for engine management. It is compatible with almost any steel trigger wheel - see popular accessories for available options.
This variable reluctance (reluctor) sensor comes complete with a 2-way Bosch-style plug, including terminals and boot, for easy and reliable installation.
  • Variable reluctance (reluctor) sensor
  • Includes Plug Kit - 2-way Bosch Style plug, terminals and boot
SKU: CAS
  • Link crank angle sensor (CAS) for engine timing and trigger system applications
    مستشعر زاوية الكرنك
  • Link Crank Angle Sensor (CAS) for engine position monitoring, shown in a compact black housing
    طقم توصيل ثنائي الاتجاه من CAS
تحميل رابط الكمبيوتر
