انتقل إلى المحتوى
تسجيل الدخول
يبحث
يبحث تسجيل الدخول عربة التسوق 1
عربة التسوق
أنت مؤهل للحصول على الشحن المجاني.
  • AiM Car PDM32 power distribution module, front view, module only
    AiM Power Distribution Module PDM32 - Module Only
    Title:
    Default Title #MWS Options 3413481709
    £1,940.00
    إزالة
إطلب تعليمات خاصة
المجموع
£1,940.00
عرض عربة التسوق
يبحث
Link KnockLink G4 tuning tool by Link for engine knock detection and monitoring
Link G4 KnockLink tuning tool by Link for engine knock detection and monitoring
G4KNL
Link KnockLink G4
سعر البيع£169.15
السعر العادي £199.00
  • شارك على الفيسبوك
  • شارك على الواتساب
  • فيسبوك شارك على الفيسبوك
  • واتساب شارك على الواتساب
Link KnockLink G4
سعر البيع£169.15السعر العادي £199.00
Link KnockLink G4 - #G4KNL
KnockLink is a self-calibrating, visual knock warning tool. The KnockLink is designed for tuning, street and race use. It will require a knock sensor to function (sold separately) or you can purchase the KnockLink Kit that includes the Knock Sensor and Loom.
The G4 KnockLink is the only detonation warning device on the market that requires no setup. Other systems require time-consuming gain, frequency and noise settings to be adjusted. Without proper knock listening tools, this can prove difficult if not impossible. The KnockLink requires none of this, just wire in and start the engine.
Even light detonation will damage an engine over time. The G4 KnockLink's microprocessor continuously scans the knock signal and warns for any knock occurring. The engine's RPM and load are automatically 3D profiled by the KnockLink, continuously storing and dynamically adjusting this noise profile map while looking for the particular knock frequency.
Simple Operation
The colour of the LED represents four different modes:
Dim Blue - KnockLink is powered, waiting for the engine to be started
Flashing Blue - KnockLink has detected the engine has started and is now calibrating
Dim Green - KnockLink is adapting to the engine's noise profile and listening for knock
Flashing Red - KnockLink has detected knock. Avoid large throttle openings, seek professional advice.
  • KnockLink G4
  • الأسئلة الشائعة
  • برمجة
  • فيديوهات الدعم
  • دليل المنتج PDF
  • اتصل بنا
  • كن سفيرا
  • الإصلاحات
  • دعم الدردشة المباشرة &
  • يفتح في نافذة جديدة.
