LiveU Solo PRO (HDMI فقط) جهاز بث فيديو مباشر 4/5G
The UK’s Leading Live Streaming Device
Take your live streaming to the next level with LiveU Solo PRO – the professional-grade, portable video encoder trusted by motorsport creators, sports teams, videographers and broadcasters worldwide.
Whether you’re transmitting SmartyCam 3 GP, GP Pro, or Dual footage straight to the pit, or streaming live to YouTube, Facebook, Instagram, Twitch and beyond, the LiveU Solo PRO delivers broadcast-quality 4K video with the reliability and freedom you need.
Why Choose the LiveU Solo PRO
Get rock-solid performance even in challenging network conditions. Enjoy up to 20Mbps streaming and optional HEVC/H.265 encoding for maximum quality at minimum bandwidth. Available in HDMI or SDI versions, the LiveU Solo PRO ensures your live streams look as good as your vision.
Designed for Creators
Join thousands already using the Solo Creator Universe (SCU):
- IRL Streamers – Go live anywhere, wire-free and stress-free. Add Solo Connect PRO, your creativity and a camera – then just go!
- Production Houses – Stream live events from anywhere with IP-video over bonded 4G/5G, no cables or venue networks required.
- Sports Teams – Bring fans closer with easy-to-use, budget-friendly, broadcast-quality live streams.
- Educational Institutions – From sports coverage to media training, the LiveU Solo PRO offers primetime results in a cost-effective package.
- Videographers – Trust award-winning tech with HEVC, 4K, LRT™, long battery life and lightweight mobility so you can focus on storytelling.
Future-Proof Your Streaming
With the next-gen Solo PRO encoder, you can stream to any leading social platform or website. Simply connect your camera or switcher, log in via the web-based Solo Portal, select your destination, and go live.
Solo Creator Universe Services & Accessories
- LRT™ Bonding Technology – Adaptive bitrate, bonded connections, and unmatched stability. Available monthly or annually.
- Solo PRO Connect Kits – Complete plug-and-play packages with modems, data plans, and LRT™ included (two or four modem options).
- Stream Tools – Multi-destination streaming, stream fallback, and logo watermark for enhanced brand presence.
- Solo Belt Pack – Comfortable, practical, and designed for streaming on-the-go. Includes Y-cables, HDMI pigtail cable and space for modems/routers.
Trusted Worldwide
The LiveU Solo PRO is used by global broadcasters and streaming partners including:
Facebook, YouTube, Twitch, Vimeo, Twitter/X, Amazon Live, Dacast, Streann, Switchboard, Ustream, Grabyo, LinkedIn, Restream, Jstream.
Stream without limits – wherever the action takes you.
LiveU Video/Audio Encoder
2x Angled USB 2.0 Type A Cable
HDMI Female - HDMI Male Cable
HDMI Voltage Clip
UK, EU & US Power cables
