انتقل إلى المحتوى
تسجيل الدخول
يبحث
عربة التسوق
  • متابعة التسوق
    إطلب تعليمات خاصة
    المجموع
    عرض عربة التسوق
    يبحث
    Second-Life Cobra ECU - AimShop.com
    اسرع، بقي 1 عنصر فقط في المخزون!
    سعر البيع£384.00
    السعر العادي £480.00
    • شارك على الفيسبوك
    • شارك على الواتساب
    • فيسبوك شارك على الفيسبوك
    • واتساب شارك على الواتساب
    Product Image
    سعر البيع£384.00السعر العادي £480.00
    This Cobra Motocross ECU is fully equipped and ready to take on its second life. The ECU is in full working order and has been meticulously checked by our technicians.
    Ain Cobra ECU Plug & Play Engine Control Unit
    Cobra is an aftermarket plug & play ECU created by Aim, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
    This specific Cobra ECU is unprogrammed. It can be configured for any brand or model bike you require. You will need the UC Bridge Tuner to enable this process.
    Once the unprogrammed Cobra ECU has been configured with a dedicated brand or model it can not be changed. You will be able to modify the maps written into the ECU but the brand or model which has been configured can not be changed.
    Cobra Key Features & Advanced Strategies
    Traction Control
    Traction Control Strategy
    Launch Control
    High Technology 32-bit Core
    Engine control requires precision. At 20,000 RPM the Cobra ECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
    Tuner License :
    This is the Tuner that is required to configure the unprogrammed Cobra ECU.
    *Please Note: For information regarding the UC-Bridge Tuner, please contact one of our Aim technical team for further information.
    Cobra ECU Connections
    The Cobra ECU has 4 connectors :
    2nd CAN Connector - Connect to the UC Bridge, to communicate with the PC.
    3rd Connector - Connect to spare analogue inputs and a possible second injector.
    Below shows a functional diagram of products that can be added to the Cobra ECU:
    Aim Cobra ECU Plug & Play Engine Control Unit
    • One low side driver (1 A)
    • Two CAN Bus, one for calibration purposes, one for expansions - (Aim handlebar switch, data loggers, dash etc
    • Power consumption 150 mA
    • n. 1 33 pin male Connector
    • Body: PA6 + 30% glass fibre
    • Waterproof: IP67
    • Weight: 260g
    • ECU Cobra Control Unit
    Video
    User Guide Tuning Manual Technical sheet Race Studio 3 Spark Tuning Software
    • يفتح في نافذة جديدة.
