This Taipan ECU comes back to us as a trade-in, fully equipped and ready to take on its second life. The ECU is in full working order and has been meticulously checked by our technicians.
Aim Taipan ECU Plug & Play Engine Control Unit
Taipan is the brand-new aftermarket plug & play ECU created by Aim, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
This specific Taipan ECU is unprogrammed. It can be configured for any brand or model bike you require. You will need the UC Bridge Tuner to enable this process.
Once the unprogrammed Taipan ECU has been configured with a dedicated brand or model it can not be changed. You will be able to modify the maps written into the ECU but the brand or model which has been configured can not be changed.
Injection main alpha-n
Injection main speed-density
Injection crank correction
Pre-injection
Injection BAP Correction
Injection EWT Correction
Injection IAT Correction
Injector Battery Correction
Injector 2
Ignition BAP Correction
Ignition EWT Correction
Ignition IAT Correction
Ignition Opening Transient Correction
Ignition Closing Transient Correction
Launch Control
Injection Launch Control Main Table
Ignition Launch Control Main Table
Quick Shift
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the TaipanECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
Tuner License :
This is the Tuner that is required to configure the unprogrammed Taipan ECU.
*Please Note: For information regarding the UC-Bridge Tuner, please contact one of our Aim technical team for further information.
Taipan ECU Connections
Main Connector - Compatible with most off-road bikes. CAN Connector - Connects to the Handlebar Switch and Data Logger. 2nd CAN Connector - Connect to the UC Bridge, to communicate with the PC. 3rd Connector - Connect to spare analogue inputs and a possible second injector.
Up to 5 selectable maps
Apply fuel corrections
Activate traction control
Activate launch control
Two 0-5V analogue inputs sampled @ 1,000 Hz each, could be alternatively used as a switch to ground
Second injector driver for high impedance saturated injectors (12Ω)
One low side driver (1 A)
Two CAN Bus, one for calibration purposes, one for expansions - (AiM handlebar switch, dataloggers, dash etc
