USB إلى 712 كابل برمجة مفتوح 7 دبوس
Connect Your System
The USB to 7-pin Open Programming Cable allows for seamless, easy and quick connection to your PC to access our free Race Studio 3 software. With a USB cable on one end and a 712 7-pin Binder on the other end, it's a reliable product that specifically allows you to securely connect and configure CAN messages across different product networks.
Why Choose the Aim Open Programming Cable
Every Open device features a 7-pin connector to be connected to a PC via a dedicated USB cable. With the Open programming cable, configuration of your data is made easier than ever before. With a connection from an Aim Open product to the technology of your choice, you can simply configure the output of the Open device by setting IDs, messages, baud rate and frequency.
712 إلى كابل USB مفتوح
