NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Bike Data Logging Kit
£1,055
The Aim bike data logging kit provides you with the complete data logging setup to monitor and help improve your performance on track or road.
The kit includes:
  • EVO4S data logger
  • GPS08 module
  • Manufacturer specific plug and play connector lead (optional)
  • 3 patch leads
  • Suspension sensors - 75mm and 150mm Potentiometer Pop End Fitting (optional)
  • Brake pressure sensor (optional)
  • Standard CAN & K-Line cable (for bikes that are not supported with our plug & play leads)
 * Optional display for the data logger can be purchased here.
The EVO4S Motorcycle Racing Data Logger samples all the information you need: data coming from your vehicle ECU, internal accelerometers, internal gyro and GPS08 module (included in the kit). Also get data from analog/digital inputs, external expansions as well as predefined math channels.
The suspension potentiometer sensor included in the kit allows you to measure linear displacements like:
  • dampers compression or extension
  • steering rotation measured through the rack displacement
The brake sensor pressure allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in Motorsport.
ECU Information
BMW S1000RR (2010-2019)
Ducati 848, 1098, 1198
Ducati Panigale 899/959/1199/1199R/1299
Ducati Panigale V4
Ducati Hypermotard 796 (2009-2011)
Ducati Multistrada 1200 (2010-2011)
Honda CBR 1000RR (2004-2016), Honda CBR 600RR (2003-2016)
Kawasaki ZX-10R Stock/Racing kit MY2011/2016/2018, Kawasaki ZX-6R
MV Agusta F3 from 2012, MV Agusta F4 from 2013
Suzuki GSX-R 600/750/1000 (2001-2016)
Suzuki GSX-R 1000 (2017 onwards)
Yamaha YZF-R1/R1M from 2015, YZF-R6 from 2017
Yamaha YZF-R1 2004-2014, Yamaha YZF-R6 2004-2016
