Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    AiM Ultimate GS Dash & EVO4S Motorcycle Data Logging Kit - AimShop.com
    EVO4S-1-GS-DASH-SUS-POT-75-SUS-POT-150-P-712-719-10-P-712-719-10-S-P-B-M10-P-712-719-10-APR-PP
    Aim GS-Dash & EVO4S Motorcycle Data Logging Kit
    På lager, klar til afsendelse
    Choose Accessories
    £2,502.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    Product Image
    £2,502.00
    The Ultimate GS-Dash & EVO4S Motorcycle Data Logging Kit
    We have put together the ultimate motorcycle data logging kit to help improve your racing performance.
    GS-Dash with LCD screen
    7 configurable RGB colours
    5 configurable RGB LED shift lights
    4 configurable RGB alarm LEDs
    5 pin 712 male spiral cable
    Many options for ECU connection
    Built-in accelerometer & gyro sensor
    5 fully configurable analogue channels
    EVO4S Data Logger
    CAN output
    2-speed inputs
    75mm & 150mm potentiometers
    Two 712-719 patch leads
    Brake pressure sensor M10-0-100 bar
    One 712-719 patch lead
    GPS module 1.3m
    Motorcycle Compatibility
    We have an extensive range of ECU motorcycle cables for you to choose from for the following bike models: Aprilia, BMW, Ducati, Honda, Kawasaki, MV Agusta, Suzuki, Triumph and Yamaha.
    Motorcycle GS-Dash
    The Aim GS-Dash is a compact, flexible and fully configurable graphical display showing data sampled by our EVO4S.
    This dash is small in dimension, which makes it particularly suitable for motorbikes. It features a five-pin binder 712 male spiral cable, which will enable you to connect your EVO4S with minimum effort.
    The GS-Dash can be backlit in one of seven available colours. It also features an ambient light sensor that makes brightness and contrast ideal in all light conditions.
    The GS-Dash is compact in structure and features a 268x128 pixel display to maximise readability.
    Configurable Pages, Alarms & LEDs
    The GS-Dash can swap among pages showing lap times and data customisable to suit your needs. You can choose the data and create pages displaying up to eight fields in each. The RPM lap time page layout is available to display the RPM graph, lap time and three channels of your choice.
    You can visualise the rolling time or static or predictive lap time (as an absolute value or as a difference vs the best lap).
    The GS-Dash features five RGB shift lights, which can be individually configured for each gear, choosing LED colour and RPM threshold values for their activation.
    Alarm LEDs work in a very flexible way. You can choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch off. You can also show a warning message.
    When your session is over, you can easily recall your sampled data by your EVO4S data logger. The summary will display data such as the best laps of the session with times, min/max speed and min/max RPMs.
    EVO4S Data Logger
    The Aim EVO4S is a powerful and flexible data logger equipped with a 1.3m GPS Module. Offering one connector per channel, the EVO4S samples all the information you need, data coming from your bike ECU via the specific bike cable you have selected, from the internal accelerometers and gyro and the GPS Module included in the kit.
    Sensors
    Five fully configurable analogue channels with configurable 12-bit o-5 Volt, 0-5000 mV inputs or thermocouple input, used to sample data coming from the temperature, pressure, suspension and other sensors.
    Tri-axial accelerometer and gyro is a built-in inertial platform that allows you to understand oversteering, understeering, banking, etc. Additional features include:
    • 2 speed inputs for differential wheel behaviour
    • 2 CAN Interfaces for vehicle control expansion
    • 4GB internal memory
    • ECU interface - CAN-Bus, RS232, K-Line and OBDII
    • RPM input for square wave or pulse signals
    Sensors Included In The Kit
    Suspension Potentiometer With Pop End Fitting
    The Aim suspension sensor (linear potentiometer) is a type of position sensor. They are used to measure displacement along a single axis, either up and down or right & left, and suitable linear potentiometers are a contacting type of sensor which means that the moving parts contact each other during use.
    Please Note: This kit comes with 2 potentiometers, a 75mm and 150mm; both also come with a 712-719 1 meter patch lead.
    Brake Pressure Sensor M10 0-100 Bar
    The Aim M10 - 0-100 Bar brake pressure sensors have a male four pins black 719 binder plug connections to suit all Aim loggers and dash display/loggers. Whether your bike is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allows you to monitor brake performance, make fundamental changes and identify issues quickly and precisely.
    Please Note: This kit comes with an M10 0-100 bar brake pressure sensor and a 712-719 1 meter patch lead.
    GPS Module
    The Aim GPS technology marks a true revolution in data acquisition, offering immediate access to lap times and all the critical data needed to refine your driving performance and technique. The included GPS09 Module connects easily via a CAN cable for fast installation and ensures outstanding precision and reliability by working with nearly twenty satellites.
    With an average positional tolerance of less than one meter, the system can accurately detect the start/finish line, even when the finish line is close to another track segment. The module locks onto satellite signals rapidly, becoming fully operational as soon as it's powered on, and is resistant to signal loss from noise or interference.
    Paired with GPS Manager software, you can track start/finish lines and split points, and access a comprehensive track database. The system also delivers essential insights such as chassis analysis, real time track position, speed, cornering forces (both in-line and lateral G), and automatic lap timing—everything you need to push your performance to the next level.
    Please Note: This kit comes with a 1.3 meter GPS Module.
    With Race Studio 3, you can also analyse all data recorded by kit and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
    • GS-Dash:
    • Ambient light sensor: Yes
    • Shift lights: 5 configurable RGB LEDs
    • Display pages: Fully configurable
    • Body: Aluminium
    • Pushbuttons: Metallic
    • Dimensions: 127.8 x 82 x 22.2mm
    • Weight: 380g
    • EVO4S Data Logger:
    • ECU connection: CAN, RS232 or K-Line to 1,000 industry leading ECUs
    • External modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
    • Anologue inputs: 5 fully configurable, max 1,000 Hz each
    • Digital inputs: 1 (1 Amp max)
    • Internal platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
    • Internal memory: 4 GB
    • Connectors: 13 Binder connectors
    • Body: Anodised Aluminium
    • LEDs: 1 system status
    • Dimensions: 130 x 35 x 46.6mm
    • Weight: 330g
    • GPS Module:
    • Weight: 60.5g
    • Brake Pressure Sensor M10 0-100 Bar:
    • Supply: 8-16V
    • Accuracy:  < +/- 0.5% FS (CLNH – combined non-linearity and hysteresis)
    • Characterisation: 500mV/ O bar 4500mV/ 100 bar
    • Sealing: IP66
    • Weight: 30g
    • Cable length: 400mm
    • Thread: M10
    • For all other technical information, please refer to the Technical Sheets in the Download Tab.
    What's In The Box
    • EVO4S Data Logger
    • GPS09 Module 1.3m
    • GS-Dash
    • Potentiomter 75mm & 150mm
    • Brake Pressure Sesnor M10 0-100 Bar
    • 3 x 712-719 Patch Leads
    Aim GS-Dash User Guide
    Aim GS-Dash Technical Sheet
    Aim Technologies Race Studio 3 Software Download
    GS-Dash GS-Dash Tech Race Studio 3
    Aim EVO4S User Guide
    Aim EVO4S Technical Sheet
    Aim GPS Module Technical Sheet
    EVO4S EVO4S Tech GPS Module
    • Opdater siden
    • Åbn i et nyt vindue
