Gå til produktinformation
1 af 2
AiM Hall Speed Pick Up Sensor 719 Plug 2m Cable
SKU: S-S-H719
Normal pris
£70.00
Normal pris
Udsalgspris
£70.00
+ moms (kun Storbritannien)
Drevet af Shopify Planet
Hall effect wheel speed sensor 719 plastic connector
2m cable M8 thread
719 Connection to suit MXL (Strada and Pista), MXG/MXS/MXP (inc Strada), MXL2. Use a 719-719 Patch Lead to extend to the required length.
  • 719 plug Binder Connector
  • Power Supply: 10-30 VDC
  • Sensor Thread: M8
  • Waterproof: IP67
  • 1 x Hall Effect Speed Sensor 719 Plastic connector 2m Cable
2m cable M8 thread
  • Sensor Thread: M8
  • Waterproof: IP67
