Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim OTK Kart Throttle Position Sensor Magnet Holder - AimShop.com
    AiM OTK Magnet Holder For Throttle Position Sensor - AimShop.com
    Til OTK Karts
    Til gashåndtagspositionssensor
    B-OTK-T-MH
    £25.00
    Til OTK Karts
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £25.00
    This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.
    Suits AiM throttle position sensor kit Specific OTK karts
    Fits to the throttle cable
    This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the magnet to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the sensor is available to purchase separately.
    • Suits AiM Throttle Position Sensor Kit
    • Suitable for OTK Karts
    • Fits to throttle cable
    • 1 x Magnet Holder for Throttle Position Sensor
    • Ofte stillede spørgsmål
    • Support videoer
    • Produktvejledning PDF
    • Kontakt os
    • Bliv ambassadør
    • Reparationer
    • Opdater siden
    • Åbn i et nyt vindue
