AiM Water/Oil Temperature Sensor PT100 M10 Thermo Resistor Motocross
SKU: S-T-M10
- Normal pris
- £70.00
- Normal pris
- Udsalgspris
- £70.00
- Pris per stk
- om
AiM Water/Oil Temperature Sensor M10 Thermo Resistor
The AiM PT100 M10 Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature | 4 pins 719 male binder |
PT100 - M10 |
Sensor cable length 25cm
- Temperature working range: 0/150°C
- Cable sensor length: 250mm
- M10 Thermo resistor
- 4 pins male 719 Binder connection
- AiM Water/Oil Temperature Sensor M10 Thermo Resistor
The AiM PT100 M10 Thermo resistor temperature sensor is suitable for reading water and oil temperatures.Key Features :
PT100 - M10 |
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Water_Oil_Temperature_Sensor_M10_Thermo_ResistorMain_image.png?v=1624614077)
The AiM oil/water (coolant) temperature sensor is fitted with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Failure to operate engine or gearbox oil within the correct temperature range can reduce efficiency, reduce power transmitted to your wheels and drastically reduce longevity.The Thermo resistor must put in the cooling system/oil sump.
![AiM Water/Oil Temperature Sensor PT100 M10 Thermo Resistor Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMWater_OilPT100ThermoResistorM10ThreadMotorcycle2_3ad27b2a-12b5-4dc4-8722-1ffd46282362_1445x.png?v=1613495000)
![AiM Water/Oil Temperature Sensor PT100 M10 Thermo Resistor Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMWater_OilPT100ThermoResistorM10ThreadMotorcycle_5e0aa571-43fe-4a93-86f9-873a03315a44_1445x.png?v=1613495000)
