Motorcycle Plug & Play Data Logging Kit
The Solo 2 DL data logging kit is compatible with Suzuki, Aprilia, BMW, MV Agusta, Triumph, Yamaha, Honda and Ducati motorcycles
This plug & play kit with the Solo 2 DL gives you the ultimate track day experience. It includes the Solo 2 DL, 2 suspension potentiometers, an analogue CAN converter (ACC), a brake pressure sensor and a motorcycle-specific plug & play cable.
Video laden: Solo 2 DL kit on Ducati motorcycle
Plug & Play Compatibility
Building on the features of the Aim Solo 2 model, the Solo 2 DL motorcycle plug & play kit connects directly to your motorcycle's ECU to record vital engine data, without the need for complex wiring. Please refer to the user guide on how to connect the ECU cable to your motorcycle.
The plug & play cable currently fits the following bike models:
  • Aprilia
  • BMW
  • Ducati
  • Honda
  • MV Agusta
  • Suzuki
  • Triumph
  • Yamaha
Please Note: For these models, Aim recommends not to remove the stock dash. Doing so will disable some of the motorcycle's functions or safety controls.
Powerful Combination
The kit comes with a variety of accessories to improve your motorbike setup:
  • Solo 2 DL: A data logging lap timer that handles an ECU input with a CAN expansion port that you can connect a SmartyCam to.
  • Bike Plug & Play Cable: The kit comes with a specific cable to connect the Solo 2 DL to the bike model that you have selected to relay all vital ECU information.
  • Brake Pressure Sensor: Brake pressure sensors are used to measure how much force is applied by the rider to the brake. When combined with suspension potentiometers, you can get a greater understanding of your bike setup.
  • Suspension Potentiometer: Measures the travel of the suspension forks on your motorbike to understand your suspension setup.
  • ACC (Analogue CAN Converter): Adds four freely configurable analogue/digital channels without occupying or modifying the existing system channels.
Solo 2 DL is compatible with Suzuki, Aprilia, BMW, MV Augusta, Triumph, Yamaha, Honda and Ducati motorcycles
The Solo 2 DL has a sharp, high-contrast display which helps sailors easily identify the data displayed on screen, as well as 8 different backlight colours.
The Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no map already, the device will create one for you.
Brake pressure sensor is available in PSI or Bar variants
The brake pressure sensor allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in motorsport.
These brake pressure sensors are available in a range of sizes as well as PSI and Bar variants.
ACC3 with 4 channel harness
Like all Aim devices, the Aim ACC3 is built for motorsport applications. Its compact design ensures easy installation across a range of racing vehicles, while its robust construction guarantees reliability in demanding environments. When combined with Race Studio 3 software, the ACC3 unlocks powerful configuration and analysis tools, including suspension analysis with Aim Eclipse sensors and video synchronisation with SmartyCam 3 cameras.
  • Thermo Resistors
  • 0–5V Sensors
  • 0–12V Sensors
Inertial Platform
The Solo 2 DL calculates, displays, and records lap times, sector times, position & vehicle speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro. This allows you to see your exact racing line, compare it to optimal lines for faster lap times, track the motorcycle's movements and provide detailed data on acceleration, braking, and cornering forces.
Video laden: SmartyCam & Solo 2 DL data being analysed on Race Studio 3
The data recorded from the Solo 2 DL and the connected sensors can be combined in our free analysis software, Race Studio 3.
This allows you to review your driving and compare data such as speed, G-forces, throttle position and more, and acts as a performance tool to assist you in improving your driving skills by providing a visual reference for driving lines and technique.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
  • IP67
SKU: SOLO2-K-YAM-4-ACC-SUS-POT-75-SUS-POT-150-S-P-B-M10-BP-DB-P-719-719-5-P-719-719-5-P-719-719-10
Note: Please refer to the relevant user guide in the free downloads tab for the pinout drawing for the specific plug & play connection cables & sensors.
  • Solo 2 DL
  • Power Cable with AC Adapter
  • Battery Charger with AC Power Adaptor
  • Your Chosen Connection Cable
  • Aim Suspension Potentiometer - AimShop.com
    x2 Suspension Potentiometers
  • AiM ACC 3 Analogue CAN Converter - AimShop.com
    ACC3
  • Aim Oil / Fuel Pressure Sensor 0-5 Bar - AimShop.com
    Brake Pressure Sensor Adaptor
    Double Banjo Bolt
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Aprilia User Guide
BMW User Guide
Ducati User Guide
Ducati Panigale User Guide
Ducati Panigale V4 User Guide
Ducati Hypermotard User Guide
Ducati Multistrada User Guide
Honda CBR User Guide
Kawasaki User Guide
MV Agusta User Guide
Suzuki GSX-R User Guide
Triumph User Guide
Yamaha User Guide
ACC Tech Sheet
Potentiometer Tech Sheet
Videos
Overview
Video laden: An in-depth review of the main features and functions of the Aim Solo 2 DL motorcycle lap timer.
