SmartyCam 3 Sport
SKU: SM3-SP-XS3S672G
- Regulärer Preis
- £665.00
- Regulärer Preis
- Verkaufspreis
- £665.00
- Stückpreis
- pro
Capture. Replay. Overlay. Analyse.
*Please Note: The SmartyCam 3 Sport must be powered and connected to another Aim device such as the Solo 2 DL, MXM, or an MX-Series Data Logger/Strada Logger, in order to receive all CAN information. Please also be aware that the camera MUST be externally powered by any of these products as the internal battery is only competent for initial configuration.*
The new SmartyCam3 Sport saves all your data to a supported micro-SD card for up to 2TB of data. This includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam3 automatically powers on and off in-sync with your engine and will auto start/stop recording, the parameters of this being personalised by the user.
Analyse your data from a vast range of sources such as ECU information, GPS information, track map, vehicle position, speed, lap & split times. Video format is at H.264 1920x1080 pixels, 30 FPS, and the display resolution of 128x128 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Quality
Anatomy
Higher Storage Capacity
SD cards sold separately.
Video format: H.264 1920 x1080 pixels @ 30 fps
- CMOS sensor: Global Shutter
- Field of view: 84°
- External power: 9-15 Volt
- Support microSD card: Up to 2 TB
- Connectors: 1 Binder 712 female
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 79.9 x 54 x 46.5 mm
- Weight: 200g, battery included
- SmartyCam 3 Sport
- Data Hub (Optional)
- 12v Mains Charger
- 2m / 4m CAN Cable
Quality
Anatomy
Technical Specifications
Whats in The Box
- SmartyCam 3 Sport
- 12v Mains Charger
- 2m / 4m CAN Cable
