1 von 5
Yamaha YZF-R6 Motorcycle Aim Solo 2 DL & SmartyCam 3 GP Plug & Play Track Day Kit
SKU: SOLO2-K-YAM-4-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256920CS-X47SOLO2DL02
Regulärer Preis
£2,210.00
Regulärer Preis
Verkaufspreis
£2,210.00
A Powerful Track Day Combination
Solo 2 DL & SmartyCam GP For Yamaha YZF-R6
The Yamaha ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Please Note: For these models/years, Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
Plug & Play Compatibility
Yamaha YZF-R6 (YEC included) - 2004-2005
Why Choose The Solo 2 DL For Yamaha YZF-R6 Motorcycles
Solo 2 DL Key Features
Direct ECU Data Logging
Predictive Lap Timing
Extensive Track Database
8 Different Colour Backlights
Multiple Race Modes: Speed, Times & Performance
Integrated GPS & GLONASS Receiver
8 Configurable Display Pages
Automatic Track Recognition
Internal 4GB Memory
Wi-Fi Connection
10 Configurable RGB LEDs
Yamaha ECU Connection Cable
Precise Lap Times
Aim Solo 2 DL is the most precise GPS lap timer there is with the ability to show you your lap time live as you drive. Receiving data from two satellite constellations from anywhere on the globe by using GPS and Glonass also giving you a significant improvement in data speed and positioning precision.
Solo 2 DL Track Database
Why Choose The SmartyCam 3 GP For Yamaha YZF-R6 Motorcycles
SmartyCam 3 GP Key Features
TFT Colour Display
Full HD Recording
Real Time Overlay Videos
Automatic Start/Stop
Live Streaming Bullet Camera
Choice of lens - 67°, 84°, 120°
K-YAM-4-SM-CAM
Yamaha YZF-R6 Aim Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 25 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Yamaha YZF-R6 Plug & Play connection cable
  • Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 2 washers M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
Internal 4GB Memory
Wi-Fi Connection
Precise Lap Times
TFT Colour Display
Full HD Recording
K-YAM-4-SM-CAM
  • GPS: 25 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 2 spacers
  • 2 washers M6
  • 4 washers M6
  • 2 washers M4
