    €0,00 EUR
    Aim 712 Male 7-Pin to 712 Male 5-Pin SmartyCam CAN Cable - AimShop.com
    712-712 Patch Lead
    5-Pin to 7-Pin Male
    High-Quality Connectors
    Various Sizes Available
    SM-CAN
    €47,95 EUR
    712-712 Patch Lead
    5-Pin to 7-Pin Male
    €47,95 EUR
    AiM SmartyCam 2.1 HD CAN Harness
    The AiM CAN harness is required to connect the SmartyCam 2.1  HD.
    Suitable for 2.1 HD CAN harness
    Available in  2m and 4m
    The AiM CAN harness for the SmartyCam 2.1 HD SmartyCam camera. This lead is required to connect the SmartyCam to an AiM dash/logger or data hub.
    712-5 pin male to 712-7 pin male
    High-quality cables and connectors
    Provides you with flexibility for better SmartyCam location
    • CAN Harness
    • 712 5 pin male to 712 7 pin male
    • Suitable for SmartyCam 2.1 HD
    • 1 x SmartyCam 2.1 HD CAN Cable
