Aim 90-Degree Bolt-On Dash Bracket
Free Shipping Above £100
Mount Your System
The Aim 90-Degree Bolt-On Dash Bracket is designed to mount Aim Dash Displays or other modular components. Crafted from 2mm raw stainless steel and bent at a 90-degree angle, the bolt-on bracket ensures a secure and durable connection for your racing setup.
Why Choose the Aim 90-Degree Dash Bracket
The Aim 90-Degree Bolt-On Bracket simplifies the installation of dash-mounted components, providing a sturdy and reliable mounting solution. Its modular design allows for easy integration with various Aim accessories, offering flexibility and adaptability in your racing setup.
Essentially, the Aim 90-Degree Bolt-On Bracket is used to enhance the functionality and organisation of your dashboard for a professional and efficient setup.
