Required for Taipan B (Beta Motors)
Required component for Taipan B installation on Beta stock version.
The Beta OEM Idle Motor is not compatible with our Taipan B ECU.
To ensure proper operation, we provide a dedicated AirPlug. If the original throttle body is replaced with a non-Beta throttle body (e.g. KTM, Honda) the AirPlug is not required.
  • Required component for Taipan B installation on Beta stock version.
  • The Beta OEM Idle Motor is not compatible with Taipan B. To ensure proper operation, we provide a dedicated AirPlug.
  • If the original throttle body is replaced with a non-Beta throttle body (e.g. KTM, Honda) the AirPlug is not required.
