Aim Car Steering Angle Rotary Potentiometer/Belt Type Sensor
Steering Angle Rotary Sensor
The Aim Steering Angle Sensor Kit is suitable for use with Aim loggers, displays and display loggers. It comes with a bracket for easy installation and is ideal for various 10 revolution motorsport car & bike setups.
Why Choose the Steering Angle Rotary Potentiometer
The Steering Angle Rotary Potentiometer measures and records the driver’s steering input using a sensor (rotating potentiometer) to measure the displacement between two points. Using the Steering Angle Sensor, you can see where time is being lost due to steering angle; too much or too little at each corner.
Steering Angle Rotary Sensor Connections
The Car & Bike Steering Angle Sensor is available with or without a 719-719 or 712-719 male to female 4-pin patch lead, which is required to connect the sensor to any Aim logger, dash display and display logger. For most setups, you will need the 719-719 patch lead to connect to logger harnesses that have 719 connectors, which are available in various lengths from 0.5 to 4 metres. If you're connecting to loggers such as the EVO Series or Channel Expansion, you will need the 712-719 patch lead.
10G Steering Potentiometer
Toothed Belt
x2 Toothed Pulley
Allen Key
Bracket Kit
